Spoon Calipers, which one do I need ?
Which Spoon Calipers would I need to run on an Integra that's not an ITR?
I'm pretty sure it's not just a bolt on... So what's needed to install them ?
Unless, the set comes complete?
Thanks.
Thanks.
I think they were only offered for the DC2R.
http://www.spoon.jp/product/pdfs/p62_p69.pdf
You can do this conversion to run 282mm rotors or get a 5-lug swap.
https://honda-tech.com/zerothread?id=734560
I don't know if I would be willing to machine those calipers to make them fit. Perhaps you could locate a 2mm spacer for between the hub and the rotor.
