***DA vs. EF Suspension parts interchangeable Q?***
Old Dec 8, 2007 | 09:29 AM
Outkasted24's Avatar
Default ***DA vs. EF Suspension parts interchangeable Q?***
I have found that the Upper front/rear strut tower bars along with the front lower tie bar for all EF & DA's are interchangeable, Is it possible for a rear lower tie bar for EF fit on a DA too?
Anyone have experience with this or maybe can measure the distance between both points on a DA and on a EF Civic/CRX to see if they are the same?
Thanks in advance for any info
-Jeff
Old Dec 12, 2007 | 04:28 PM
Default Re: ***DA vs. EF Suspension parts interchangeable Q?*** (Outkasted24)
Anyone?
Old Dec 15, 2007 | 06:29 PM
Old Dec 15, 2007 | 06:37 PM
1200 Hobos's Avatar
DAs and EFs are the same car suspension wise. I think it's all interchangeable but I'm not 100% sure. Under the car it's all the same, If you can interchange the Upper strut tower bars from EF to DA then the lower part shouldn't be any different. THey're basically the same thing.
Old Dec 16, 2007 | 04:22 PM
Default Re: ***DA vs. EF Suspension parts interchangeable Q?*** (1200 Hobos)
Hmmmm, Thanks for the info,............But I wish I could have a solid answer from someone that has tried to install a solid rear lower tie bar from an EF to a DA
Old Dec 16, 2007 | 05:03 PM
0bd1_Kanobe's Avatar
Exept for the subframe I belive its all the same, front and rear.
Old Dec 16, 2007 | 06:36 PM
650teg's Avatar
I would call up Honda (or even an aftermarket company) and ask if the part numbers are the same.
Tippyman
51
Aug 17, 2014 06:09 PM
Tippyman
Aug 7, 2014 09:21 PM
Blue-EM1
Suspension & Brakes
Jul 15, 2007 08:10 PM
whiteguyndahood
Nov 25, 2006 08:01 PM
