Brake Job on 2006 Civic EX - Need Help ASAP
OK...well...I've changed brakes on about 20 cars in my day and have never ran into this...
I have the car up in the air right now and took the calipers off. Went to take the rotors off and it looks like they have 2 phillips head screws holding them on. I have broken 3 tools trying to get one screw out with no luck.
Anyone have a clue on how to get the damn rotors off??????????????
PLEASE HELP!!
Thanks,
Tom
PLEASE HELP!!
Thanks,
Tom
Go buy this...
http://www.sears.com/shc/s/p_1...river
You put it into the screw, then hit the back with a hammer. It should be loose after that...
Your ITR has the same design. All but a few Honda's have the rotor retaining screws.
If you end up damaging the phillips head to where you can't get a #3 phillips head in there anymore, use a chisel and sledgehammer to break it loose by rotating it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC »</TD></TR><TR><TD CLASS="quote">If you end up damaging the phillips head to where you can't get a #3 phillips head in there anymore, use a chisel and sledgehammer to break it loose by rotating it.</TD></TR></TABLE>
I did just this on my itr, so I dremled a slit into the head of the screw and used the flat head on the impact driver and got that damn bolt off. This is another alternative to the chisel and sledgehammer.
Thanks for the response guys...I went out to buy the tool the day I did this and got all of them off with ease.
By the way...R is sold as of September. I never changed the brakes on the car...it never had enough miles on it.
Just wanted to say thanks...you guys kick ***!
Tom
Tom
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant »</TD></TR><TR><TD CLASS="quote">Go buy this...
You put it into the screw, then hit the back with a hammer. It should be loose after that...</TD></TR></TABLE>
thats what i did when i install rear slotted and drilled rotors for my friends RSX. sure it took an hour for me to get it off but at least it worked lol.
never knew that tool existed, i should look into it. thanks Nish
btw your s2k was siick
2000CivEx
Mar 18, 2003 06:05 PM
