what kind of head
i asked this question before but didn quite get a straight answer, i pulled a junker motor for a rebuild, its a zc single cam vtec, now i need to buy parts for the valvetrain, its out of a 92 civic so that would make it a a d16z6 head right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d-series-buildup »</TD></TR><TR><TD CLASS="quote">i asked this question before but didn quite get a straight answer, QUOTE]
[QUOTE=d-series-buildup], its a zc single cam vtec, now i need to buy parts for the valvetrain, its out of a 92 civic so that would make it a a d16z6 head right?</TD></TR></TABLE>
You didnt get a straight answer cause your not asking a straight question if its out of a 92 civic it isnt a zc single cam it is a z6 in which case yes you buys parts for a 92-95 civic si hatch or ex coupe.....it is a usdm motor correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboZChatch »</TD></TR><TR><TD CLASS="quote">You didnt get a straight answer cause your not asking a straight question if its out of a 92 civic it isnt a zc single cam it is a z6 in which case yes you buys parts for a 92-95 civic si hatch or ex coupe.....it is a usdm motor correct?</TD></TR></TABLE>
There are multiple engines stamped "ZC," including SOHC, SOHC VTEC, and DOHC. The SOHC VTEC ZC, which he indicated that he has, is essentially a D16Z6.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d-series-buildup »</TD></TR><TR><TD CLASS="quote">i asked this question before but didn quite get a straight answer, i pulled a junker motor for a rebuild, its a zc single cam vtec, now i need to buy parts for the valvetrain, its out of a 92 civic so that would make it a a d16z6 head right?</TD></TR></TABLE>
Yes, you can use all D16Z6 parts. The head should be stamped P08.
jdm_eqsi
Nov 14, 2005 10:39 PM
