rebuild bottom end
Old Dec 8, 2007 | 08:42 AM
ekBlackHatch's Avatar
Default rebuild bottom end
So im rebuilding my jdm c5 this month and was looking for some more displacement for my n/a build. wondering how far i should bore
i was trying to reach 1.9 or 2.0. Do i need to resleeve the block to reach 1.9 I think the most to go on stock sleeves is 82mm no? Or could i get away with a block gaurd. Im a novice so please any info asap would help i have to send my block out to the shop in 2-3weeks and need to order pistions and whatever else to do this rebuild reliable with cast pistions thanks for your time
Old Dec 8, 2007 | 09:07 AM
coolhandluke's Avatar
Default Re: rebuild bottom end (ekBlackHatch)
~82mm is about the max bore for a stock/non-sleeved bottom end.
Have you fully researched the costs associated with a 2.0L build? I have build sheets of estimated costs, but many others in this forum can give you real costs from their own builds. Its not a cheap task, but I am by no means trying to convince you from building. I just want to make sure you know the real costs of the build.
What are you plans for the car?
Old Dec 8, 2007 | 09:14 AM
Default Re: rebuild bottom end (coolhandluke)
i just wanted a little more displacement but keep it reliable and a weekend road/race. I know it cost money, im not intirely sure on how much i just strarted doing research on it yesterday. I know ill use either oem p30 pistions or RSpr3's.
please im welcome to any advice
Old Dec 8, 2007 | 10:22 AM
Casey's Avatar
82 bore with an 89 crank will get you some displacement youll notice
Old Dec 8, 2007 | 10:37 AM
Default Re: rebuild bottom end (Casey)
whats a 89 crank do i use my same rods then i assume
Old Dec 8, 2007 | 10:42 AM
Casey's Avatar
ls crank and ls rods
Old Dec 8, 2007 | 10:02 PM
will 82mm be safe by itself on stock sleeves or do i need to get a block guard or what not thanks i need somthing that will hold 100kish miles
Old Dec 9, 2007 | 07:28 AM
so i can buy a GE 89 ls crank for 330 is that a fair price? then i need the ls rods also correct?
Old Dec 9, 2007 | 11:17 AM
92TypeR's Avatar
FSAE
82mm bore + 91mm Eagle crank + rods = 1922cc
82mm bore + LS 89mm crank + rods = 1880cc
Unless you are boosting, no need for a block guard.
My build came out to just over $3,000 for my Benson sleeved 2.0L bottom end (85mm). This included all parts and assembly by Laskey Racing.
Old Dec 9, 2007 | 02:41 PM
Default Re: rebuild bottom end (92TypeR)
if i go with the eagles what cr would i be looking at aiming for around 11:5:1
Old Dec 10, 2007 | 05:09 PM
whoohoo got me some rsmachine 82mm pr3s and ls rods
Old Dec 10, 2007 | 05:16 PM
92TypeR's Avatar
FSAE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekBlackHatch &raquo;</TD></TR><TR><TD CLASS="quote">whoohoo got me some rsmachine 82mm pr3s and ls rods</TD></TR></TABLE>
Don't forget to use ARP rod bolts.
Old Dec 10, 2007 | 06:52 PM
yup plan togotta find some for cheap still need a crank though
Old Dec 12, 2007 | 02:29 PM
so i rounded up most the parts for the bottom end....
cleanrice was nice enough to hook me up with a ls crank and i ordered the ls rods and some RSmachine 82mm pr3 pistions so should get interesting after i pick up some arp goodies
Old Dec 14, 2007 | 02:09 PM
k got a question with my build, 1.8litier with a comp of 11:7:1 rocket head package, performerX IM, 310cc injectors and blah blah my question is what header would you recomend most for a 1.8 high comp and why over the other brand. Im looking at the bisi, ssr (sweeper), smsp, t1r response and an-r
please post some pics 2 if you want
Old Dec 14, 2007 | 04:58 PM
92TypeR's Avatar
FSAE
SSR Street Sweeper
If you are looking to retain PS/AC, the SSR B-Unit is also good. They are roughly equal in the midrange, then the Street Sweeper carries further.
On the INTEC DynoJet, a B-Unit made 12whp over a JDM 4-1, and the Street Sweeper made another 6-7 over the B-Unit, this is on a mild 1.8L build mind you.
Old Dec 14, 2007 | 08:40 PM
hot damn!!!! that sounds nice... wish i could get my hands on a narrow rmf
S2Integra
Aug 26, 2009 03:07 PM
alexx19
Mar 20, 2007 09:59 AM
flip1199
Apr 24, 2003 03:12 PM
