question on parts for rear disc convertion on a 90 4dr
i know you need to get the trailing arms rotors pads 4040 prop valve but my question is as far as brake lines and ebrake cable goes do i order from a teg crx or my own civic. also do i have to drop the tank on the 4dr cause i've read on some forums that the crx's you don't have to
u can use the cables off of the teg or a crx with rear disk only cant use the stock drum ebake cables and as far as the lines i believe u have to swith those also ...well i did when i did my conversion hope this helps
