obd2 mani in obd1 car...sensor questions
Car: 94 dx
Motor: d16y7
Intake Manifold: d16y8
The car doesn't run, I bought it 3 weeks ago to replace my stolen hatch and I'm using parts I have laying around to make something to drive. So far to use this manifold I have plugged in the map, iac, extended to the fuel return line and rerouted a bunch of vac lines. Here's what's giving me issues:
The white sensor on the back of eg intake manifolds...i needed to put the plug in the harness in something so I unscrewed the sensor from another junk manifold, put the plug in it and now it's just hanging there...what is it? what does it do? I check majestichonda and that just says sensor...TA.
Where does the pcv valve go on the y8 manifold? I took one from an eg, used the appropriate vac lines, plugged it into the harness and now it's just chillin there...this is okay right? And even if it is..I want to do it the right way so help me out.
Motor: d16y7
djaxis
Feb 22, 2010 06:48 AM
Shiftpointshaun
Mar 27, 2004 07:37 PM
