clutch master cylinder and clutch- help?
Old Jun 26, 2002 | 03:22 PM
juniordc2's Avatar
Default clutch master cylinder and clutch- help?
I opened the cap the the master cylinder and I noticed there wasn't any fluid in there, and I can't seem to see the fill lines? Also my car shakes vigorously when I start off in 1st gear sometimes, and the clutch friction point is lower than normal maybe 1/4 of the time. Whats wrong?
Thanks
Old Jun 26, 2002 | 06:54 PM
ALF's Avatar
ALF
Default Re: clutch master cylinder and clutch- help? (dc2gsr94)
For the cylinder, you simply fill it up until you see the floater "float." Sounds like it needs replacing ASAP. Check your firewall and if you see fluid leaking, you need to get it changed. More likely than not, a new one will also cure your friction point problem.
For now, bleed the clutch and see if that helps at all.
Old Jun 26, 2002 | 09:32 PM
juniordc2's Avatar
Default Re: clutch master cylinder and clutch- help? (ALF)
nope, no fluid leaking whatsoever.. what kinda dot fluid should I put in the clutch res.?
Old Jun 26, 2002 | 09:47 PM
ALF's Avatar
ALF
Just put any DOT3 brake fluid in there.
Old Jun 26, 2002 | 10:49 PM
juniordc2's Avatar
any other explanation about my starting problems?
Old Jun 27, 2002 | 12:43 AM
Dutchie's Avatar
I am having the same problem you are. My car even makes a little metal grinding sound once in a while when I start off in 1st. I bet if you lift the dust cover off of the slave cylinder there will be fluid there. You may not need a master cylinder, and just a slave cylinder. They are about $70. For now just keep filling it, and bleed it.
Old Jun 27, 2002 | 10:37 AM
juniordc2's Avatar
Default Re: clutch master cylinder and clutch- help? (Dutchie)
where is the slave cylinder?
Old Jun 27, 2002 | 10:40 AM
juniordc2's Avatar
did that solve the problem of the shaking when starting the car?
Old Jun 27, 2002 | 10:46 AM
MrBite's Avatar
Look in the front of the engine bay, right to the passenger side of the heat shield. there's a bleeder bolt sticking off of a metal thing there--that's the slave cylinder. if you want I can scan in a page of the helms manual this evening to show you
Old Jun 27, 2002 | 11:07 AM
Dutchie's Avatar
I will let you know, I am doing mine tomorrow.
Old Jun 27, 2002 | 10:13 PM
juniordc2's Avatar
ok cool, keep in touch
Old Jun 27, 2002 | 10:31 PM
Dutchie's Avatar
Does your car ever make a little metal screeching sound when you start off in 1st? Just wondering, I don't think it is from the Slave, but it started to happen shortly after my slave went.
Old Jun 27, 2002 | 10:54 PM
juniordc2's Avatar
sometimes, when I start off, my original friction point is there.. but at other times, my friction point is noticably lower and it feels like it just hooks up automatically real fast.. i am thinking about changing my clutch/pp
Old Jun 28, 2002 | 06:16 AM
StockTeg's Avatar
If you need a clutch master cylinder, I'll sell you my extra for $90 shipped(brand new are about $150 from the dealer). Needs the gasket. You could reuse the one on you car.
[Modified by StockTeg, 3:16 PM 6/28/2002]
Old Jun 29, 2002 | 08:00 AM
Dutchie's Avatar
Well, I did my slave cylinder and the car feels good now. I still get that noise because I need new axle seals. The slave only cost me $80 Canadian.
Old Jun 29, 2002 | 11:35 AM
juniordc2's Avatar
nice, 80cdn? thats good for me.. so your friction point thing is fixed?
Old Jun 29, 2002 | 11:54 AM
Dutchie's Avatar
Ya, it's fixed. Just make sure you bleed the clutch well. It took me forever to get mine to bleed right.
Old Jun 29, 2002 | 02:41 PM
fuko's Avatar
how many km's do you have on your clutch? is it a stock one?
Old Jul 1, 2002 | 10:30 AM
Dutchie's Avatar
Default Re: clutch master cylinder and clutch- help? (fuko)
About 60,000 km, and it is a Clutchmasters I think.
Old Jul 1, 2002 | 11:45 AM
ebelp's Avatar
I did mine a few months ago at around 100k, took me 1.5 hours and $140. Not too bad...
Old Jul 2, 2002 | 08:33 AM
GM2000ITR's Avatar
New User
I may be able to help you..........check my sig below!
Gomdohree
Apr 24, 2008 06:20 AM
gsr1289
Aug 22, 2006 07:11 PM
707EF8
Jul 29, 2006 08:09 PM
tytyguy
Dec 3, 2005 02:32 AM
94TeGsR
Jan 14, 2003 09:00 AM
