kygb shocks question
Old Dec 7, 2007 | 05:06 PM
superslow-oto's Avatar
Default kyb shocks question
i have k sports and they are too stiff for daily driving. its is really good on corners, but then too stiff for daily driving...so the question is, would kyb shocks with HR springs be more comfortable... i drive a 94 hatch..
Modified by superslow-oto at 10:49 PM 12/7/2007
Old Dec 7, 2007 | 06:22 PM
blk92_d16's Avatar
Switch the KYBs for Koni Yellows.
Old Dec 7, 2007 | 08:29 PM
laocivic's Avatar
Default Re: (blk92_d16)
stay away from the kyb gr2's...they ride worst than stock and handle only decent. H & R springs ride great and seat pretty low too. i have tokico illumina's and they ride great. you can try those
Old Dec 7, 2007 | 08:50 PM
blackcivic11's Avatar
Default Re: (laocivic)
you can also try KYB AGX i have em and love em
Old Dec 7, 2007 | 09:13 PM
AutoXer's Avatar
Default Re: (blackcivic11)
I had AGX and they were complete crap. Adjustment did almost nothing, and after about six months they were total ish. On 2 of them the rods were completely seized up (if I remember correctly). On one of the other ones, the rod went in, made a gurgling noise, and I couldn't pull it back out again. You're beter off with stock.
Old Dec 7, 2007 | 10:15 PM
Neebs's Avatar
Koni Yellow are best for you.
Old Dec 7, 2007 | 11:09 PM
EJ1_Sleeper's Avatar
Default Re: (Neebs)
I've had k-sports and I completely understand what you mean.
I switched those with AGX shocks in the front with 500lb rates (dropzone ftl) and GR2s in the rear with 450lb rates.
About 2 months ago I finally picked up a set of Ground control springs (380f/250r) and kept the shocks the same. The GR2s are now blown (I ride slammed and these are only a stock replacement), and the AGXs are like new still. The adjustability is great, soft - teeth chattering stiff. I love the AGXs, but everyone swears by koni and illuminas as well.
And for your springs, do you want adjustability? or just one height?
The most common set up that everyone loves is the Ground Control coilover springs with Koni Yellow shocks.
Depending on the set up your looking for, there are plenty perfect shock too spring combo.
anymore questions pm me ill be glad to help out.
Old Dec 12, 2007 | 09:34 PM
AutoXer's Avatar
Default Re: (EJ1_Sleeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1_Sleeper &raquo;</TD></TR><TR><TD CLASS="quote">AGX shocks in the front with 500lb rates (dropzone ftl) and the AGXs are like new still. The adjustability is great, soft - teeth chattering stiff.</TD></TR></TABLE>
Have you pulled them off and checked them? I ran mine with Eibach springs for a few months and they were dead. It wansn't just one, but all, with catastrophic failures. Even when I first put them on and went to my first autocross, I barely felt a difference between full soft and hard. Hell, even my revalved Konis can't go from super comfortable to bone jarring in any way; that's a component of springrate. What a good adjustable shock will do is allow you to adjust how the shock handles the spring action. From my experience, the AGX wasn't even close to handling the task...
Smash03
Suspension & Brakes
Dec 5, 2007 10:28 PM
IntegraLs94Cam
Honda S2000
Aug 13, 2007 04:57 AM
Manolo
Suspension & Brakes
Oct 25, 2006 12:09 PM
SL!M
Jun 1, 2003 06:37 PM
Seedc2
Oct 29, 2001 12:22 AM
