A/C experts! Regarding pully size & compressor speed...
Old Dec 7, 2007 | 03:26 PM
HiProfile's Avatar
Default A/C experts! Regarding pully size & compressor speed...
I've been thinking about this for my car, which is turbocharged with AC, but PS removed. The stock crank pulley has a 5.5" diameter for the AC, but the PS step next to it has a 3.5" diameter. The reason I want to move the belt to that pulley is mainly for space, as it gives and extra inch for wastegate placement, and even more if I move it upwards too. I don't boost w/o turning the A/C off, so I don't care about high rpm parasitic loss.
The obvious problem is the compressor's reduced speed, which is ~36% less. Since 90% of my driving when the A/C is on is on the highway, should I worry about the compressor speed reduction? I'm guessing the worst case scenerio is that it won't pump enough R-134 when the engine is idling. I could increase idle to compensate, and I know my car increases idle even more when AC is on.
BTW the AC system will get a fresh recharge next year, right after being professionally 'vacuumed'.
Old Dec 9, 2007 | 03:14 PM
HiProfile's Avatar
Default Re: A/C experts! Regarding pully size & compressor speed... (HiProfile)
Nobody has a clue? Thats uncommon...
Robert Campbell
Jun 17, 2019 03:46 PM
adan CRX
Dec 1, 2003 03:12 AM
Jeager521
Sep 12, 2003 12:28 PM
rodimus
Jan 19, 2003 04:00 PM
