rear mount removal
Old Dec 7, 2007 | 02:41 PM
code47mastermind's Avatar
Default rear mount removal
I currently have a b18b in my 90 hatchback
I originally installed AVID mounts with a 70A firmness
I am swapping them out for a set of innovative mounts which are 60a
my question is: Is it possible to remove the rear mount from the rear cross member without removing the entire engine?
thanks in advance
Old Dec 7, 2007 | 03:26 PM
jwbnavy's Avatar
Default Re: rear mount removal (code47mastermind)
Its tricky but can be done from under the car. Better with two people.
Old Dec 7, 2007 | 03:49 PM
eda6's Avatar
i did this today w/o a helper..removed avid mount and attempted to replace with an innovative mount.
dizzy and starter removed, car already on jackstands. had all the bolts out in 15 minutes. took a while to get the mount out of the L bracket. mount came out from the top and the l bracket came out from the bottom.
Old Dec 8, 2007 | 01:21 PM
Default Re: rear mount removal (eda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">i did this today w/o a helper..removed avid mount and attempted to replace with an innovative mount.
That is good to hear. I am glad I won't have to take out the engine
LastSamurai
Apr 22, 2011 08:48 AM
vtechrex
Nov 28, 2005 12:13 PM
jdub db8
Nov 26, 2004 09:30 PM
mattL
May 25, 2004 12:32 PM
CristalCleanCivic 97 EX
Aug 8, 2003 10:39 AM
