half size fluidyne radiator on 89 crx (hf)
Old Dec 7, 2007 | 12:01 PM
whitef's Avatar
Default half size fluidyne radiator on 89 crx (hf)
im pretty sure someone did this
but do they work fine?
also if anyone has issue, pls post.
lmk, im about to purchase one.
thanks
Old Dec 7, 2007 | 12:25 PM
thevtecnician's Avatar
Default Re: half size fluidyne radiator on 89 crx (whitef)
I used one from an eg civic on my 88 hatchback. I was using traction bars instead of the regular front crossmember. I had to cut both my hood and my front radiator support. Actually had to cut the stock radiator holder out of the support and basically make room for the rad. Or you could just lean it back but that looks kinda ghetto. Sorry no pics.
Old Dec 7, 2007 | 12:31 PM
89hatcher's Avatar
i got mines to fit ...cause i got a placeracing crossmember...no cutting of hood.
Old Dec 7, 2007 | 01:54 PM
whitef's Avatar
Default Re: (89hatcher)
thanks for all the infos
not sure if i should get it now
not planing to cut hood or change the crossmember
i thought it would fit right in maybe just adjusting the the mountings.
Old Dec 7, 2007 | 02:34 PM
ludesrv's Avatar
What you do, don't do this:
Old Dec 7, 2007 | 06:50 PM
alscrx's Avatar
Default Re: (ludesrv)
WTF????????
Old Dec 25, 2007 | 10:25 PM
fc3srx729's Avatar
that's tight...
Old Dec 25, 2007 | 11:01 PM
abnaasefmb's Avatar
Default Re: (fc3srx729)
pics in sig, did not fit with full race T-bar, was too tall.
Old Dec 26, 2007 | 07:36 PM
mellowbeam's Avatar
Default Re: (abnaasefmb)
i've heard of people using the half size rad for their setup, but only if you have an aftermarket xmember. All I think is required is a fabricated mounting bracket like the EG's have. Its especially functional with a turbo sitting tidy next to.
Old Dec 26, 2007 | 08:02 PM
crx2nr822's Avatar
Default Re: (mellowbeam)
I think the half size Full Race radiators fit underneath a stock crx hood
Old Dec 26, 2007 | 08:28 PM
dr_latino999's Avatar
Default Re: (crx2nr822)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx2nr822 &raquo;</TD></TR><TR><TD CLASS="quote">I think the half size Full Race radiators fit underneath a stock crx hood </TD></TR></TABLE> That they do, but you have to get the one made for the traction bar. It fits nice and tidy under my hood
Old Dec 26, 2007 | 08:57 PM
nihad's Avatar
i have heard that the oem ones back in 88 crx hf had the small half size not the one that are new but the oem ones that u would find on a hf crx. are the size and will fit with all oem civic half size.
Old Dec 27, 2007 | 01:54 AM
civickiller's Avatar
Default Re: (nihad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nihad &raquo;</TD></TR><TR><TD CLASS="quote">i have heard that the oem ones back in 88 crx hf had the small half size not the one that are new but the oem ones that u would find on a hf crx. are the size and will fit with all oem civic half size.</TD></TR></TABLE>
ive never heard of that, can anyone confirm?
you can use a neon radiator, you just need to mount a cap somewhere
Old Dec 27, 2007 | 02:20 AM
mr.speaker's Avatar
Default Re: (civickiller)
Thats not a Half radiator,it's more like a 3/4 radiator,and it's stock on all HF's,not just 88'
Big picture warning
http://www.metricmind.com/ac_h...l.jpg
Old Dec 27, 2007 | 04:46 AM
dem0nk1d's Avatar
what in the world is that motor?
xJu1c3x
Dec 6, 2007 11:35 PM
SupraRXZ
Dec 18, 2006 04:30 PM
planoguy36
Apr 6, 2006 10:05 PM
FOMULA91
Jan 7, 2006 01:24 PM
d16dcoe45
Nov 20, 2005 01:20 PM
