FS: 1.9l b16a2, 84.5, AEBS sleeved, Crower crank, TITANIUM RODS, custom Wiseco pistons, Race head MO
SO, i HAVE to sell my baby URGENTly in order to gather funds for my new business.
MOTOR SET (MONSTER!!!) - built to hold up to 800whp reliably... fully assembled, 2000 miles. READY TO BOLT INTO YOUR CAR!!!
b16a2 (legit, all vins)
BOTTOM END:
-stroker 1.9l
-84.5mm custom Wiseco pistons
-Crower TITANIUM RODS
-AEBS sleeves
-Crower 84.5mm stroker crank
-oil pan tapped
-ARP new headstuds
-Cometic headgasket
-NEW ITR oil pump
-NEW oem waterpump
-rlz decked & honed
-new timing belt
-LS crank pulley
**ALL LINES, HOSES, SENSORS included, as well as MOUNTS, alternator, etc... OBD1**
HEAD and TURBO:
-port and polish gasket match and cambers deburred
-OmniPower valve springs and retainers
-Crower valves
-CTR cams (or a set of Brian Crower Stage 3 Turbo cams instead... even trade)
-RC550 injectors
-Turbonetics t3t4 turbo .63 stage V, good up to 500whp - 200 MILES ON IT!!!
-PeakBoost RamHorn manifold - tapped for EGT
-PeakBoost 3" downpipe
-Godspeed high flow alluminum radiator
-2.5" chargepipes, couplers, t-bolt clamps
-NEW TiAL bov (v-band)
-NEW TiAL 38mm wastegate
-Edelbrock VictorX intake manifold
-AEM high flow fuel rail (red)
-MSD 6AL ignition, box, cap, everything
-Denso Irridium plugs
-Nology HotWires
-ebay oil catchcan
-Moroso ventury crackcase kit
-AEM EMS
-IBM thinkpad laptop - perfect for tuning AEM EMS sofware pre-installed
-valve cover tapped for 2 breather lines
-3" custom mandrell bent exhaust w/ 3" flexpipe and 3" resonator
-all oil lines
-all vacuum lines
-Skunk2 cam gears
-Greddy oil adaptor
-AEM boost controller
-AEM map sensor
-AutoMeter cf boost gauge
TRANNY:
-b16 hydro
-fully rebuilt, all new bearings, checked clearances,
-new 2nd and 3rd gears
-carbon coated syncros
-BRAND NEW axles w/ lifetime warranty (new axle seals also)
-ACT stage 3 six puck race disk
-extreme pressure plate
-12lb flywheel
-OBX lsd, rebuilt
The motorset is ready to be dropped in, everything except for an intercooler is there. even obd1 vtec wiring harness. as it sits it will make 500whp from the first tune. with larger injectors and bigger wastegate and turbo it will make M O R E !!!
You can reach me via IM (not prefered) Email (titus.bulzan@gmail.com) or phone 919-264-2007
I am located in Raleigh, NC
you can check my reputation via CarolinaHondas.com (i am a moderator there and 100% reputation as a member) also, eBay feedback rating of 100% on over 100 feedbacks... "ihrteam22"
BOTTOM END:
-stroker 1.9l
-AEBS sleeves
-oil pan tapped
-ARP new headstuds
-Cometic headgasket
-NEW ITR oil pump
-NEW oem waterpump
-rlz decked & honed
-new timing belt
-LS crank pulley
HEAD and TURBO:
-Crower valves
-RC550 injectors
-Nology HotWires
-ebay oil catchcan
-AEM EMS
-all oil lines
-all vacuum lines
-Skunk2 cam gears
-Greddy oil adaptor
-AEM map sensor
TRANNY:
-b16 hydro
-12lb flywheel
-OBX lsd, rebuilt
ricin4ever
Feb 12, 2014 03:48 PM
slick1851
Jul 6, 2010 06:43 PM
slick1851
Jul 6, 2010 01:33 PM
FS: 1.9l b16a2, 84.5, AEBS sleeved, Crower crank, TITANIUM RODS, custom Wiseco pistons, Race head: p
Patriciah22a
Dec 11, 2007 08:06 AM
