I have a stock 01' GSR....what kind of head and motor work should i do?...
Old Dec 7, 2007 | 06:51 AM
JDMblackGSR01's Avatar
Default I have a stock 01' GSR....what kind of head and motor work should i do?...
I have a stock GSR with about 90k on it.......i was thinking about doing some head work to it......and was wondering what other people have done and what they would recommend me do, etc.......
Like should I bother buying a newer Type R head, since my GSR has 90k on it and its a direct bolt on, just looking for some suggestions.......
basically I want a quick all motor Integra.......at least 200hp......like type R status....
Thanks
Old Dec 7, 2007 | 06:55 AM
AWD Terror's Avatar
Default Re: I have a stock 01' GSR....what kind of head and motor work should i do?... (JDMblackGSR01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMblackGSR01 &raquo;</TD></TR><TR><TD CLASS="quote">like type R status....
Thanks </TD></TR></TABLE>
You're not shooting that high.
Get some cams, I/H/E, spray some nitrous, and your there
Old Dec 7, 2007 | 07:27 AM
St Jimmy's Avatar
* B A N N E D *
If you want...... itr status...... then do what.... a itr has..... like pistons..... cams..... and a bunch..... of freaking..... boltons.... along with a tun....ee..... and you will..... be..... set.....
Old Dec 7, 2007 | 10:19 AM
Schister66's Avatar
Man U FTW
Default Re: I have a stock 01' GSR....what kind of head and motor work should i do?... (St Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by St Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">If you want...... itr status...... then do what.... a itr has..... like pistons..... cams..... and a bunch..... of freaking..... boltons.... along with a tun....ee..... and you will..... be..... set.....</TD></TR></TABLE>
I cant think of any way to write more annoying than that...
To the OP: If you're looking for 200whp NA, you're going to have to gut that GSR and get some new internals. I really dont think its possible to make 200whp NA without tearing into it. I would get a set of CP Shelf pistons in an 81.5 mm (overbored) at your desired compression ratio and use that as a starting point for your build....by the way boost is cheaper and better
Old Dec 7, 2007 | 10:41 AM
St Jimmy's Avatar
* B A N N E D *
Default Re: I have a stock 01' GSR....what kind of head and motor work should i do?... (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">
Agreed.....UNLESS IT WAS IN CAPS TOO!!!...
Old Dec 7, 2007 | 10:58 AM
AWD Terror's Avatar
Agreed.....U..N...L...E..S...S....IT........WAS IN......CAPS TOO!.......one......!!......</TD></TR></TABLE>
fixed
mynameizstitch
Apr 8, 2013 07:43 PM
Seto-Initial-B
Oct 12, 2007 07:28 PM
94whitegsi
Sep 25, 2006 12:02 PM
HondaRacer32
13
May 3, 2004 06:31 PM
KRiS1
Sep 4, 2003 04:51 PM
