1988 CRX ECU Pin Out Diagram OBDO to OBD2B ?
Old Dec 6, 2007 | 10:02 PM
luvcivics's Avatar
Default 1988 CRX ECU Pin Out Diagram OBDO to OBD2B ?
I have a 1988 CRX and swapped a B18C into it can someone hook me up with the ECU Pin Out Diagram please
Old Dec 6, 2007 | 10:08 PM
luvcivics's Avatar
Default Re: 1988 CRX ECU Pin Out Diagram OBDO to OBD2B ? (luvcivics)
my crx is a 1988 Si my JDM Motor is a 99 B18C
Old Dec 6, 2007 | 10:17 PM
stillsmokey's Avatar
Why not swap to obd1 to make things much easier? Seems like you are making it way more complicated than it has to be.
Old Dec 6, 2007 | 10:33 PM
luvcivics's Avatar
ya u are rite but its too late for that now my 99 B18C is already in with the Hasport mounts and even the Cable to Hydraulic Clutch thing is all in and i went with the 99 B18C OBD2B cause of LSD
Modified by luvcivics at 12:06 AM 12/7/2007
Old Dec 6, 2007 | 11:00 PM
Loaded Butane's Avatar
Id contact rywire.
Old Dec 6, 2007 | 11:07 PM
luvcivics's Avatar
Default Re: (Loaded Butane)
who is rywire?
Old Dec 7, 2007 | 10:01 AM
Default Re: (luvcivics)
http://www.rywire.com
Old Dec 7, 2007 | 10:25 AM
90efhatch's Avatar
I would use a obd1 computer and use the rywire wiring harness.
Old Dec 7, 2007 | 01:52 PM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luvcivics &raquo;</TD></TR><TR><TD CLASS="quote">ya u are rite but its too late for that now my 99 B18C is already in with the Hasport mounts and even the Cable to Hydraulic Clutch thing is all in and i went with the 99 B18C OBD2B cause of LSD
Modified by luvcivics at 12:06 AM 12/7/2007</TD></TR></TABLE>
The mounts, transmission, and LSD have nothing to do with converting to OBD1
Old Dec 7, 2007 | 04:23 PM
IMALLSLO's Avatar
Not gonna happen. To go OBD2 would take alot more work then its worth. Get yourself a OBD0 b16a or GSR,P28 Ecu w/ a jumper harness and be done with it.
Old Dec 9, 2007 | 09:50 PM
luvcivics's Avatar
Well I would like to wire this up the way I set out to so if soemone could link me to the Wiring and ECU pin outs that would be great ... I know its a lot of work but its not impossible and I know some of you know of somebody that has done it the way I set out to
Another question I have is what do i do with my speedo it is cable and now I am going Hydraulic?
Old Dec 10, 2007 | 12:19 AM
StorminMatt's Avatar
Default Re: 1988 CRX ECU Pin Out Diagram OBDO to OBD2B ? (IMALLSLO)
Then again, JDM OBD2a is just basically like OBDI with different plugs. This might be an easier way to go if you want a cheap ECU.
Old Dec 10, 2007 | 02:49 PM
luvcivics's Avatar
Default Re: 1988 CRX ECU Pin Out Diagram OBDO to OBD2B ? (StorminMatt)
No i jus want to try it the way i set out to , so can someone link me to the wiring diagram for the 99 B18C to go into my 1988 CRX Si wiring diagram and ECU pinout i already have a jumper harness
Old Dec 10, 2007 | 05:09 PM
dr_latino999's Avatar
No one has a direct diagram. I do know there are plenty of OBD-0 --&gt; OBD-1 and OBD-2 --&gt; OBD-1 so you'll probably have to build the chart yourself.
Old Dec 10, 2007 | 06:22 PM
Default Re: 1988 CRX ECU Pin Out Diagram OBDO to OBD2B ? (dr_latino999)
Because I'm nice
Old May 21, 2010 | 05:41 AM
mikebro's Avatar
thankz for the scoop
Old May 21, 2010 | 07:04 AM
BrayzieEF9's Avatar
u kno u commented on a almost 3 yr old thread???
Old May 21, 2010 | 09:40 AM
hatchet_honda's Avatar
HYDRO trans has nothing to do with speedo...just swap over the cable driven speedo gear from another trans. i have a 97 gsr trans with my b16 in my 91 ef. nooo prob
Old May 21, 2010 | 05:10 PM
ihaterust's Avatar
why would you tell him to get an obd0 ecu and chip it? thats ****ing dumb considering he would then need an obd0 dizzy. get a rywire obd0-obd1 conversion harness and find a p73 ecu or get a p06, p75 or p28 chipped and tuned. if you run the obd2 ecu you will have to hook up all the emmisions crap like two o2 sensors and evap purge.
Old May 21, 2010 | 07:02 PM
BrayzieEF9's Avatar
^almost 3 yr old thread guys
Old May 21, 2010 | 07:19 PM
D16SiHatch's Avatar
DualCamEJ
May 20, 2015 07:51 AM
standy xsi
Feb 19, 2012 11:04 AM
EM199dcs
Mar 6, 2006 10:02 PM
