question: ctr cams; whats the difference between exhaust and intake camshafts
Old Dec 6, 2007 | 08:09 PM
pli's Avatar
pli
Default question: ctr cams; whats the difference between exhaust and intake camshafts
so im looking to buy ctr cams and i have a few questions...
1. what are the differences between the exhaust cams and intake cams, and could i just one or the other? if so, which one?
2. if i do get one, or both, what will i need to change? i believe just valve springs? and get a fuel/pressure regulator to adjust? what about valve retainers? are they necessary?
3. are there any proven dyno tests? how much hp do you think i can get from this?
Old Dec 7, 2007 | 09:13 AM
EGmikeH22's Avatar
* B A N N E D *
Default Re: question: ctr cams; whats the difference between exhaust and intake camshafts (pli)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pli &raquo;</TD></TR><TR><TD CLASS="quote">so im looking to buy ctr cams and i have a few questions...
3. are there any proven dyno tests? how much hp do you think i can get from this?</TD></TR></TABLE>
1. the exhaust cam runs the dizzy, no switching them
2. change both not just one, and you're fine with everything else.
3. why do you want proven dyno tests. doesn't the fact that honda made them tell you that they work
Old Dec 7, 2007 | 09:35 AM
black_EM1's Avatar
Community Builder
Community Influencer
1: Here are the specs on those cams:
Intake: 11.5mm 243 @ 1mm
Exhaust: 10.5 mm 235 @ 1mm
That, and they're not interchangeable or anything silly like that.
2: It depends. If you're sticking with your stock revlimit, your valvesprings should be fine. Anything above that, actually to be on the safe side, you should change your valvesprings to CTRs. Insurance, really.
3: Well, normally a bigger cam will make more power. That's generalizing, but if you want dyno results, search. They're on here.
crazyc@SRTmotorsports
Apr 20, 2006 01:04 PM
8Si8
Aug 28, 2005 07:27 PM
hitvtecgetloud09
31
Mar 14, 2005 09:50 AM
phantoman
Nov 12, 2003 07:49 PM
vtec-outlaw
Dec 14, 2001 07:44 AM
