i have no traction with my h set up in my ek first second third which tires
Old Dec 6, 2007 | 07:41 PM
civiceg94's Avatar
Default i have no traction with my h set up in my ek first second third which tires
i need some ideas with tires just two set of tires for the front so when i drag i would put those on. any help would make me happy i need traction man its annoying thanks
Old Dec 6, 2007 | 07:42 PM
Jared's Avatar
MT drag radials
Old Dec 6, 2007 | 07:47 PM
civiceg94's Avatar
do you know any size thats where am confused at?
Old Dec 6, 2007 | 08:05 PM
Jared's Avatar
how much power?
Old Dec 6, 2007 | 09:59 PM
civiceg94's Avatar
it has kooks header 2.5 exhaust and a cheap intake thats about it dont know the power it throwing out and its chipped later on am building the motor so it could run 12's or so or maybe quicker all motor
Old Dec 7, 2007 | 06:26 AM
4piston's Avatar
Default Re: (civiceg94)
You are probably making 180hp or less. Right now you'd probably be quickest with one of those little 20x6 MTs but if you plan on making a little more power soon go with a 22x8 MT or M&H has a 22x9.5 We had a lot of luck on that tire with on a stock block H22 in an EG...but that car made 230hp. A 24.5 killed it.
Modified by 4piston at 8:46 AM 12/7/2007
Old Dec 7, 2007 | 06:43 AM
RaceProfessor's Avatar
Default Re: (4piston)
I would do 22's as well. I wouldn't go 24.5's without 250+whp.
Old Dec 7, 2007 | 10:06 AM
sittin on chrome's Avatar
Default Re: (RaceProfessor)
m+h 22x9.5x13 for the track
for the street.......bfg's + work the throttle
Old Dec 11, 2007 | 05:53 PM
civiceg94's Avatar
http://www.b20vtec.com/forums/....html
Old Dec 11, 2007 | 05:54 PM
civiceg94's Avatar
you guys think this is a good buy ?? i dont like the idea of having my car jacked up in the air just to fit slicks when i go out and play. thanks for the help so far
Old Dec 11, 2007 | 07:59 PM
PHDZINE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiceg94 &raquo;</TD></TR><TR><TD CLASS="quote">it has kooks header 2.5 exhaust and a cheap intake thats about it dont know the power it throwing out and its chipped later on am building the motor so it could run 12's or so or maybe quicker all motor</TD></TR></TABLE>
You write like my 7 year old son....use some periods!!!
Old Dec 11, 2007 | 08:04 PM
civiceg94's Avatar
ask me if i care if you have no helpful hints dont post this is not b20vtec.com
Old Dec 11, 2007 | 08:20 PM
civiceg94's Avatar
well i have h&r race springs with tokico illumina shocks no traction bar on. i dont know what kind to get or if it will work with my swap. or anymore ground clearance issue i will have
Old Dec 11, 2007 | 08:41 PM
civiceg94's Avatar
yeap
Old Dec 11, 2007 | 08:45 PM
civiceg94's Avatar
you think those tires well work good enough. the ones in the link
bertsb18hatch
May 9, 2007 06:03 AM
slowsol95
Feb 5, 2007 09:17 PM
EdBoon
Jul 28, 2005 11:51 AM
GOLDBERG
20
Nov 8, 2003 12:02 AM
