b16 into a crx si , wiring harnes???
hey i had a 91 just regular crx, i swapped in a b16a1, and turbo'd it ran great for the 3 days i had it on the road before some lady totalled it, but now im buying a 91 crx si shell and im wondering how the wiring harness will go from one to the other, cuz ive heard its alot less complicated with an si? if anyone has any information id appreciate it, my buddy did the wiring on it for me and im gonna be doing it this time so if anyone can give me some tips it would be greatly appreciated thanks
i would think that it should be a pretty simple swap do you still have the motor for the totaled one? but other than mounts it should go in basically the same with the si harness
i have the d15 harness that we converted to make it run the b16, will that just plug into the si harness? i had to run a resistor box to power the injectors cuz it had the d15 with the 2 injector/carb or w.e it was and we changed it to run the injectors so would i have to wire those in or shud things just plug in and go?
scooterbuilteh2
Aug 31, 2009 05:11 PM
str8drift
13
Nov 25, 2008 09:52 PM
prjctCIVIC
Jun 27, 2005 06:30 PM
scientifik69
Jan 5, 2003 08:13 PM
