1991 HONDA CRX HF RADIATOR REPLACEMENT TURORIAL?
Why? If you cant figure out how to replace a radiator in one of the easiest cars to do it in, you shouldn't be driving. Open the hood and look at it. Do you know how to open the hood?
...open the hood, you will see the two top metal braces with rubber in the center of them holding the upper radiator in place, unbolt the two bolts on each side, now you can lift out your radiator!. before you do any of that, kink the radiator hoses or drain the fluid, be sure to disconnect the tank as well from the top. its 4 total #10 bolts.
