Purchasing Crx
Old Dec 6, 2007 | 05:03 PM
Kseriesking's Avatar
Default Purchasing Crx
I going to purchase a 1988 crx, what should i look for in problems wt the car.
Old Dec 6, 2007 | 05:09 PM
hondasaurusrex's Avatar
Default Re: Purchasing Crx (Kseriesking)
rust in the rear quarter panels...cracked HVAC controls....torn side bolster on drivers seat....obviously engine problems (blown headgasket, burnt valves, rear main seal, etc.) rust through floor boards (under heater core)
Old Dec 11, 2007 | 04:44 AM
Default Re: Purchasing Crx (hondasaurusrex)
Thanks for the help...........
Old Dec 11, 2007 | 08:42 AM
civicmule's Avatar
look under the car for rust and cracks 2 the frame
Old Dec 11, 2007 | 09:20 AM
JustAnotherRex's Avatar
You should also check for rust around the rockers, it can frequently be masked by the plastic Honda used on the car.
Wobbling in the steering wheel / suspension while driving. (Worn bushings, tie rods, rack end bushing)
The biggies look to be covered. Rusty exhaust should be checked for too, I had an OEM one snap right off on me one time.
Old Dec 11, 2007 | 09:21 AM
ludesrv's Avatar
Weird pulls are usually important, might be signs of an accident.
Also check the spare tire area for any hammer marks or krinkles. Signs of an accident.
Old Dec 11, 2007 | 09:23 AM
Default Re: (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">Weird pulls are usually important, might be signs of an accident.
Also check the spare tire area for any hammer marks or krinkles. Signs of an accident.</TD></TR></TABLE>
Ah, true that. On that note, use the fridge magnet trick to check for bondo on car.
Also, check for rust in the rear tire area while you're back there.
And corner / headlights that don't fit well but are OEM may be a sign of a front end collision.
borregos91crx
15
Nov 29, 2011 08:24 PM
omahacrx
Sep 28, 2007 06:24 PM
Rob.
15
May 30, 2005 10:31 PM
pepin15
18
Jun 29, 2004 08:54 AM
Rainman13
Apr 12, 2004 04:15 PM
