Hasport mounts
Is there any way of finding out which grade the hasport mounts are? Like is there a code or something on the mounts or do you only know if you buy them directly from the supplier?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodvang »</TD></TR><TR><TD CLASS="quote">Is there any way of finding out which grade the hasport mounts are? Like is there a code or something on the mounts or do you only know if you buy them directly from the supplier?</TD></TR></TABLE>
If you have a press you can press the pin out and take one side of the urethane out. It will have a number printed on the inside. That number is the durometer of the urethane. It will be either 62, 70, or 88.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodvang »</TD></TR><TR><TD CLASS="quote">I just don't want more vibration then is necessary is all. </TD></TR></TABLE>
im sorry then you shouldnt get any aftermarket semi solid mounts.
i have teh street series and it vibrates my car all to hell and i have a SOHC.
plus its color coded.
I have the street urethane set and they vibrate like a MF. So I took out the L+R mounts and left the rear in and it is tolerable and still give rock solid clutch engagement with minimal engine torque during high rpm shifts. I too think that they are the best mounts out there ($$$ tho). HASport will sell you just the rear mount if you wish.
yeah i just got some hasport mount and ready to do the swap next weekend.they are the best so far.and dont go cheap on motor mounts. i have learnt the lesson
Modified by crazyguy at 8:06 PM 12/20/2007
90civicstdgold
Oct 28, 2010 01:58 AM
racingant
10
Mar 13, 2004 07:17 PM
