B16 in 88 Hatch
Old Dec 6, 2007 | 03:25 PM
x4thGenCafe's Avatar
OF THE KINGS
Default MPFI B16 into DPFI 88 DX Civic
So i had my B16A in my 91 Si but got another hatch which is an 88. Swapped the motor into it lastnight and go to plug the harness together but the 88's harness doesnt fit into my Si harness. Should i pull the harness plug from my Si and somehow wire that in ??
Kinda lost with it so some help would be greatly appreciated
Modified by x4thGenCafe at 9:29 AM 12/7/2007
Old Dec 6, 2007 | 03:29 PM
dr_latino999's Avatar
Default Re: B16 in 88 Hatch (x4thGenCafe)
It'd be easier for you to convert the new harness over to the motor, it's a PITA to repin the shock tower connections, unless you are into that sort of thing
Old Dec 6, 2007 | 05:05 PM
OF THE KINGS
Default Re: B16 in 88 Hatch (dr_latino999)
so basically youre saying im not gonna get this hatchcrap running and its impossible ?
Old Dec 6, 2007 | 05:34 PM
CRX Toad's Avatar
He is saying be patient and take your time with what you have. Unless you convert new harness over to the motor you have
Old Dec 6, 2007 | 07:14 PM
OF THE KINGS
Lemme re start
My B16 Engine Harness fits all plugs on passenger side strut tower but will not plug into driver side strut tower .
Any ideas
sorry if im not making sense this is realllllly stressful
Old Dec 6, 2007 | 07:25 PM
Default Re: (x4thGenCafe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x4thGenCafe &raquo;</TD></TR><TR><TD CLASS="quote">Lemme re start
Any ideas
sorry if im not making sense this is realllllly stressful</TD></TR></TABLE> Ehh, it could be worse. I had a tie-rod leave the steering today while I was trying to drive today, think about that Your issue here is that Honda MFG, in their all knowing wisdom changed the strut tower connections at will between the different models, and through the different years. It isn't like the newer (well less old) EG / DC / EK models where a lot is interchangeable throughout the model runs. To make it connect to the shock tower between two different harnesses, you will have to whip out wiring diagrams for the base car and the donor car from which the harness on the engine originally came from and make changes accordingly to get the chassis to match the engine harness or vice versa.
Old Dec 6, 2007 | 07:28 PM
alscrx's Avatar
Default Re: (dr_latino999)
You need to use the 88 harness with some of the vtec plugs. Its that simple
Old Dec 6, 2007 | 08:11 PM
OF THE KINGS
Default Re: (alscrx)
hows it that simple that doesnt explain anything
Old Dec 6, 2007 | 10:58 PM
OF THE KINGS
ok so i did some research and found out that the 88 hatch is dual point which i already knew but in order to have this work i need to convert it to multipoint.
ive found a bunch of Half write ups but nothing too much in detail.
Im gonna try and keep searching but if you know of any or have any write ups
PLeaseeeeeee let me in on em
Thanks guys
Old Dec 6, 2007 | 11:10 PM
whiteknightef's Avatar
wow it would have helped to know it was a dx or std. you were swapping into. hahah. make sure in the future you include ALL information on your questions and situation. Then we can help you and assist you better. Good luck!
Old Dec 7, 2007 | 05:28 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x4thGenCafe &raquo;</TD></TR><TR><TD CLASS="quote">ive found a bunch of Half write ups but nothing too much in detail.</TD></TR></TABLE> Now that's not true, the write-up I used and I suggest to all to use is clearly in the FAQ.
http://www.fourthgenhatch.net/mpfi.html
Old Dec 7, 2007 | 08:10 AM
OF THE KINGS
is it even possible for me to make my OBD0 B16 engine harness work with my 88 DX car harness at all ?
I keep being told i have to use a Si car harness or i have to get a MPFI DX engine harness . .
This is so annoying . I read the write ups but ALL i need is the driver side strut tower plug from the car to the engine to fit and it doesnt even say anything about it . Cant I just get that part of the harness off of an Si and use it instead of the DX ?
Old Dec 7, 2007 | 08:34 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x4thGenCafe &raquo;</TD></TR><TR><TD CLASS="quote">is it even possible for me to make my OBD0 B16 engine harness work with my 88 DX car harness at all ?
</TD></TR></TABLE>the DX DPFI chassis harness does not have wiring from the ECU to the engine bay for the 2 additional fuel injectors on the MPFI - it also doesn't have wiring from the ECU to the engine bay for the cylinder sensor in the MPFI distributor - these are the wires that are added when doing the DPFI to MPFI wiring changes - you need to use the DX engine harness and make the necessary changes to it
Old Dec 7, 2007 | 08:35 AM
jlicrx's Avatar
Default Re: (whiteknightef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteknightef &raquo;</TD></TR><TR><TD CLASS="quote">wow it would have helped to know it was a dx or std.</TD></TR></TABLE>all 88 hatchs were either DX or STD - there was no 88 Si
Old Dec 7, 2007 | 10:45 AM
OF THE KINGS
Default Re: (jlicrx)
so getting a dx harness and making it into an mpfi that would work then all i would have to do is wire up vtec and such then ride out ?
Boost Junkie 83
Mar 25, 2007 05:41 PM
Beau Gotti
Feb 12, 2006 02:11 PM
SkunkCrxSi
Jul 23, 2004 02:49 PM
91-teg-boy
Oct 17, 2003 09:04 PM
biggdogg
Feb 15, 2003 03:32 PM
