wall mounted and throttle body map sensor question
Hello, I swapped in a d15b vtec in my 88 civic dx. I got a new harness and ecu from rywire. Everything is cool but Im a little confused about the firewall mounted map sensor. When I got my new motor it has its own map sensor mounted on the throttle body. I dont see any place to put those little tiny hoses from the wall mounted map sensor on the throttle body. So my question is can I simply detach the connector to the wall mounted sensor and connect it to the throttle body one instead? Or do I need to get a different throttle body for use of the wall mounted sensor? If anyone has a d15b or d16z6 or any motor for that matter I guess, help me out please! I did the swap myself and this is the only thing I'm stuck on.
Alright Ill do that then, thats what I thought I could do but I wasn't sure, plus its much easier this way. Much Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">You can just connect the harness to the throttle body one, remove the wall mounted one and be done with it.</TD></TR></TABLE>
yep, same thing I did on my '89 DX
same connector, but you may have to extend the wires, unless you can free up a little length behind the firewall
