Suspension & Brakes Theory, alignment, spring rates....
How to adjust TEIN coilovers?
Old Dec 6, 2007 | 02:14 PM
Luchini's Avatar
Default How to adjust TEIN coilovers?
I bought a Civic with TEIN basics on them. I have had lowering springs but never coilovers before. How do I adjust the ride height with the spanner wrench? I bought some 15 inch wheels to replace the 17's so Id like to raise the height. Thanks
Old Dec 6, 2007 | 04:07 PM
PIC Performance's Avatar
Default Re: How to adjust TEIN coilovers? (Luchini)
The coilovers have 3 rings on them. Loosen the bottom most ring. Take your spanner wrenches and tighten the top two rings by turning them against each other as tight as you can get them. To raise the corner, use a spanner wrench on the middle ring and turn it counter clockwise. To lower, turn the top ring clockwise. Remember to tighten the bottom ring when ride height is set, and get an alignment.
Old Dec 6, 2007 | 04:49 PM
Luchini's Avatar
Default Re: How to adjust TEIN coilovers? (PIC Performance)
Cool thanks! Sounds easy.
Guess I have to find a second spanner wrench as their is only one in the trunk.
XeiaieX
Jul 25, 2012 08:38 AM
coreyhayman
Suspension & Brakes
Feb 16, 2007 07:15 AM
masaaki86
Suspension & Brakes
Feb 10, 2007 10:08 PM
BlueRex1020
Sep 28, 2006 10:06 PM
