88 Front camber kit/control arm
My crx needs a new joint to pass inspection, so I figured I would just get the adjustable skunk 2 front upper camber kit and call it a day....Seems I cannot find any upper front camber kits for this year crx anywhere...DO THEY EXIST?
this is what i need:
I looked for something like that when i did mine but never could find any. I ended up going with the Engall's. I havn't had any issues with them and been running them for about a year and a half now. Eibach is the only other company that i know that makes a camber correction kit for our car.
hum, the thing is I am not doing this to adjust my camber, I need that whole stock part to pass inspection so I figured I would just buy some aftermarket ones, but I guess they dont exist
if you want the whole control arm and ball joint the you need to look in to the rhino kits or the revo kit those are the 2 companies that make camber kits such as that four our crx i know i bought some for my civic and i put them on my rex they work
specialty products company (corp?)....... SPC for short.....makes a decent "eccentric bushing" type of kit for the front a arm that is cheap and good........good luck.......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by It’s*BOLO!! »</TD></TR><TR><TD CLASS="quote">My crx needs a new joint to pass inspection, so I figured I would just get the adjustable skunk 2 front upper camber kit and call it a day....Seems I cannot find any upper front camber kits for this year crx anywhere...DO THEY EXIST?
They exist, but you're going to spend a LOT more (for no benefit whatsoever) than you would if you just bought a single OE-type replacement arm.
</TD></TR></TABLE>They exist, but you're going to spend a LOT more (for no benefit whatsoever) than you would if you just bought a single OE-type replacement arm.
Ok dude there are a set on ebay for ef they are called http://cgi.ebay.com/ebaymotors...wItem
also some revo on there if u search they are cheap the rhino are like 70 and the revo are 150
6doorsentra
19
Jul 10, 2007 11:11 AM
azn_outlaw
Jan 19, 2002 05:03 AM
