which amp should i go with
so i'm trying to plan out my sound system...i have an 08 accord sedan...i believe they are 6.5 speakers all around...so i was planning to go with
FRONT:
http://www.bestbuy.com/site/ol...26793
REAR:
http://www.bestbuy.com/site/ol...26861
AMP:
i wanted to go with alpine amp also. which amp do u guys suggest off of the list below?
http://www.bestbuy.com/site/ol...00000
FRONT:
REAR:
AMP:
None of the amps you link will really do the job, [not enough watts to drive the Type Rs properly] although the MRP-F450 would work, [4x70W RMS into 4 ohms] your Type Rs are 110W and 100W continuous.
A better amp would be the Alpine PDX-4.150... http://www.alpine-usa.com/US-e...4.150 it's better to be overpowered then it is to be underpowered.
94
94
this one amp will run all 4 speakers? is there an amp that would do the same from best buy website? i found the amp on this site for 400...wat do u think?
http://www.onlinecarstereo.com...17194
Yes the amp will run all 4 speakers, it is a 4ch amp.
Bestbuy is an authorized Alpine dealer, onlinecarstereo.com is not, the diff. is, if you have a problem with the amp, if you get it from an authorized dealer you can take it to any authorized warranty repair shop, if you get it from a non authorized dealer, it must go back to them for warranty.
I have not heard anything bad about onlinecarstereo, yet.
94
94
do u have to get it at bestbuy? save TONS of money and get it here http://onlinecarstereo.com
thanks all for your suggestions...i was trying to get it at best buy cuz my friend works there and can get a nice discount...
now what about an amp and a sub...i'm lookin to go with a 10/12 inch sub...wat amp would go with it and wat enclosure would i need...
does anyone know if they've made a 08 dash kit yet? for a sedan.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peteysaccord »</TD></TR><TR><TD CLASS="quote">this one amp will run all 4 speakers? is there an amp that would do the same from best buy website? i found the amp on this site for 400...wat do u think?
http://www.onlinecarstereo.com...17194</TD></TR></TABLE>
You could save a little money and get this is you were on a budget:
http://www.onlinecarstereo.com...18377
It's perfect for what you need and is about 50-150$ cheaper depending on where you get it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peteysaccord »</TD></TR><TR><TD CLASS="quote">does anyone know if they've made a 08 dash kit yet? for a sedan.</TD></TR></TABLE> Pretty sure you have to get the OEM trim for the available navigation system, it will give you a double din opening.
94
94
Then you may be out of luck, I checked with both Metra and Scosche, nothing yet and no word on when.
Where does the screen go in an 08 Accord when you do get nav.?
Is the nav. screen not a double din, like in other Honda/Acura?
94
94
