ls vtec wiring schematic
this is probley a easy thing for you guys, but could anyone send me a link to some sort of template/picture. to how I will go about wiring, my vtec to my MAP sensors and my cyalnoid. It would be greatly appreciated, I cant find anything and its driving me crazy!!
You will have to run 2, 3, or 4 wires through the firewall to the ECU. Two to the VTEC solenoid, one to the knock sensor (if your ECU requires one), and one to the IAB (if you are using the gsr head with the stock intake manifold for the butterflies). Where you run these wires to on the ECU depends on your OBD version and which ECU you are using. You can ground the VTEC switch to the engine or any good ground source, so there is no reason to run that wire through the firewall.
taken from:
http://hondaswap.com/general-t...32829/
Special thanks to my friend Google.
And if thats not enough, here is a pretty complex article
http://www.sportcompactcarweb.....html
Those were just the first 2 results on google, if you would like more just let me know.
taken from:
