D16A6 mini me dizzy questions
Ok, I have a D16A6 that I am going to swap a Z6 head on but in some off the write up's I've been reading they say that the dizzy from the Z6 will need to be modded slightly to fit right. But if I went with a Y8 head the dizzy should bolt right up. My question is, will a Y8 dizzy bolt up to a Z6 head (no modding)?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_ED8 »</TD></TR><TR><TD CLASS="quote">My question is, will a Y8 dizzy bolt up to a Z6 head (no modding)? </TD></TR></TABLE>
Negative, the Z6 head has different mounting points compared to the Y8 head. You can use any OBD1/2 d-series VTEC or non-VTEC dizzy on a Y8 head and it will bolt up fine, but the Z6 head is just different when it comes to the mounting points so you'd need a Z6 specific dizzy if you're gonna use a Z6 head (or you can try to cut/modify the legs of what ever dizzy you have to make it fit the Z6 head but I don't recommend it).
Will the Z6 (OBD1) dizzy plug into my (OBD0) harness?
Nevermind, found the OBD0/OBD1 adapter harness on Rywire. Thanks for the info anyway.
Modified by Red_ED8 at 3:08 PM 12/6/2007
SPOON_BeIgHtEeNsEe
May 1, 2008 12:46 PM
keepinitsimple
Feb 17, 2005 11:32 AM
