Suspension & Brakes Theory, alignment, spring rates....
front tie bar - LCA bolts size?
Old Dec 6, 2007 | 09:04 AM
supracrx's Avatar
Default front tie bar - LCA bolts size?
installed a benen front tie bar and used the bolts that came with the benen tie bar. i dont know where i put the stock bolts for the front LCA that i replaced with the new ones....now i'm trying to take off the tie bar and the new bolts are too long.
anyone know the size of the bolts? tried looking for it on hondapartsunlimited but didnt give size...or should i just buy it at honda/acura? are they the same as the rear LCA bolts?
Old Dec 6, 2007 | 11:35 AM
Relic1's Avatar
I found another post that indicated you had a 99 integra LS, so you'd need a 12x76 bolt (90118-SR3-003)
this bolt also happens to fit every other 92-00 civic and 94-01 teg. Front inner LCA mount only. The rear is different.
if you have a CRX like you ID implies... then it's a 10x80
If you have something else then please let us know what car you have.
Old Dec 6, 2007 | 07:35 PM
supracrx's Avatar
yea 99 integra..thanks...
i should keep all my bolts from now on. 76 is the length?
12 x 1.5?
Old Dec 7, 2007 | 07:39 AM
Relic1's Avatar
76mm = length
12x1.5
but keep in mind that it's not a generic bolt, it has to be very hard to withstand the beating that the suspension is forced to accept.
ninety-five_DB
Suspension & Brakes
11
Aug 27, 2006 07:16 AM
SD_EM1
Jun 10, 2004 11:28 PM
MestizoRacer310
Jun 9, 2004 06:16 PM
Train
May 6, 2004 09:49 PM
