removing knuckle(hub)
Old Dec 6, 2007 | 08:26 AM
Mr.Death's Avatar
Default removing knuckle(hub)
I'm removing my knuckle as we speak cause I need to have a wheel bearing pressed in. I'm new to DA integras but not cars as I've worked mainly on my CRX for years.
Question.
How do I go about removing the line for the ABS which attaches to the hub? Sould I releave pressure first? How??
Old Dec 6, 2007 | 09:18 AM
hatchling37's Avatar
Default Re: removing knuckle(hub) (Mr.Death)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Death &raquo;</TD></TR><TR><TD CLASS="quote">How do I go about removing the line for the ABS which attaches to the hub? Sould I releave pressure first? How??</TD></TR></TABLE>
I'm not quite sure what you mean by relieving pressure in your ABS. The line that goes to the knuckle is the wheel speed sensor and should just unbolt. Hose the bolts down with some PB Blaster and tap it to help it penetrate. The sensor should come right off.
Old Dec 6, 2007 | 09:53 AM
Mr.Death's Avatar
Default Re: removing knuckle(hub) (hatchling37)
Alright thanks. Hub removed, wheel bearing is being pressed in as we speak.
B_Swapped93
Suspension & Brakes
Sep 28, 2018 07:52 AM
John Haggerty
Honda Civic (2006 - 2015)
Feb 8, 2014 02:56 PM
wildoutwhitegsr
Apr 29, 2013 09:06 AM
ColdScript
Jul 18, 2009 09:55 AM
JLange
Mar 12, 2003 06:03 AM
