will ba o2 sensor cause the car to not run?
Old Dec 6, 2007 | 08:11 AM
redefsir's Avatar
Default will bad o2 sensor cause the car to not run?
first of all the car is a 89 hatch with a jdm first gen B16
i have a check engine code 2 witch is the secondary o2 sensor... I think.
problem.... on the way to work this morning rpms drop then a back fire and no power.
after a couple attempts the engine starts but runs like ****.
could the o2 sensor be the culprit?
thanks....
by the way i searched already....
Old Dec 6, 2007 | 09:20 AM
gibsanez's Avatar
Default Re: will bad o2 sensor cause the car to not run? (redefsir)
Yes, a bad/not working O2 will make the car run poorly.
Old Dec 6, 2007 | 09:23 AM
redefsir's Avatar
just all of a sudden though?
i have a occasional check engine light but it never affected the engine.
then all of a sudden bam.. it wont run.
would i get a check engine light if the distributor was no good
Old Dec 6, 2007 | 10:51 AM
boostedh22lude1's Avatar
NO AN O2 WILL NOT MAKE IT DIE OR NOT RUN, IT WILL RUN RICH BUT STILL VERY DRIVEABLE, CHECK UR DIZZY, AND MAKE SURE UR ROTOR IN THE DIZZY DIDNT COME OFF, THE SCREW IN THOSE COME OFF SOMETIMES AND THE ROTOR WILL WOBBLE OF AND CAUSE THE CAR TO BACKFIRE AND DIE
Old Dec 6, 2007 | 11:04 AM
redefsir's Avatar
Default Re: will bad o2 sensor cause the car to not run? (boostedh22lude1)
thank you i will check that out!
i will keep you posted
Old Dec 6, 2007 | 11:33 AM
alscrx's Avatar
I agree it will run like crap but not backfire....check your dizzy. It could be your ignitor or coil
Old Dec 6, 2007 | 11:39 AM
redefsir's Avatar
Default Re: will bad o2 sensor cause the car to not run? (alscrx)
i will check it out...
Old Dec 7, 2007 | 03:44 AM
redefsir's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedh22lude1 &raquo;</TD></TR><TR><TD CLASS="quote">NO AN O2 WILL NOT MAKE IT DIE OR NOT RUN, IT WILL RUN RICH BUT STILL VERY DRIVEABLE, CHECK UR DIZZY, AND MAKE SURE UR ROTOR IN THE DIZZY DIDNT COME OFF, THE SCREW IN THOSE COME OFF SOMETIMES AND THE ROTOR WILL WOBBLE OF AND CAUSE THE CAR TO BACKFIRE AND DIE</TD></TR></TABLE>
you hit the nail on the head...
the screw came out of the rotor. i relpaced the screw and the engine purred like a kitten.
thanks
265Kandcounting
Dec 19, 2017 12:57 PM
JinDIESEL
Sep 17, 2004 06:33 AM
kingmonkey
Oct 27, 2003 02:05 PM
crxtreme27
Mar 26, 2003 07:04 AM
White S2k
Oct 26, 2002 11:45 AM
