'88 CRX Si tranny into my '91 STD
My concern is with the flywheel/clutch. I know I can go with the '88 flywheel, which I did think to get with the tranny. Seems to me though, a bigger (90+) clutch is better. Is my assumption incorrect? Or, should I use the '88 flywheel, clutch, and plate for simplicity's sake?
I dug up a post on HT that says I can use my 91 flywheel and pressure plate, with an '88 Accord clutch. Is that correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by agendadjs »</TD></TR><TR><TD CLASS="quote">I dug up a post on HT that says I can use my 91 flywheel and pressure plate, with an '88 Accord clutch. Is that correct?
</TD></TR></TABLE>Correct. The 88 Accord Clutch is the same size as the 90-91 Civic clutch, but has the correct tooth count to slide onto the 88 input shaft.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ONE-CAM-EF »</TD></TR><TR><TD CLASS="quote">so what difference would the accord clutch do?</TD></TR></TABLE>
He already said it...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">Correct. The 88 Accord Clutch is the same size as the 90-91 Civic clutch, but has the correct tooth count to slide onto the 88 input shaft.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK kid »</TD></TR><TR><TD CLASS="quote">cant you read
you just feel like bothering me
</TD></TR></TABLE>you just feel like bothering me
therotaryrocket
Nov 7, 2008 08:55 AM
Tyson
May 3, 2008 11:21 PM
orido 1.6
Jun 6, 2004 12:45 AM
