Alpine CDA-7822 headunit removal? (1994 Civic)
Old Dec 6, 2007 | 07:36 AM
p nut's Avatar
Default Alpine CDA-7822 headunit removal? (1994 Civic)
I feel like an a-hole posting this, but how do you remove this headunit? I've done factory units where they were held in by screws, but I removed the lower panel and looked under at the unit, but it's not secured by any screws. I tried just pushing it out, but it won't budge.
What's holding it in? Here are some crappy cam. phone pics.
Thanks in advance.
Old Dec 6, 2007 | 07:37 AM
B18C_EJ8's Avatar
Pull the black trim ring, and you'll either see the spring-loaded pins that lock into the cage, or you'll see the slots into which you'd insert the removal keys that came with the radio.
Old Dec 6, 2007 | 07:53 AM
p nut's Avatar
Does it just pop out? I tried to pull on it gently, but didn't budge. I didn't want to break anything in case it was screwed in somewhere...
EDIT: Just tried to yank it off, but didn't budge. I took some pliers and tried to pull it, but also didn't work. I know there are 2 little levers on either side of the trim. I'm guessing you move the levers to take the trim piece out? I did try that, but to no avail...
Modified by p nut at 10:05 AM 12/6/2007
Old Dec 6, 2007 | 08:20 AM
B18C_EJ8's Avatar
You're pulling on the black ring around the deck, right? Most of them just snap on, but some of the older decks have the ring molded on, and it's not removable.
The pins should slide up and out of the slot that they reside in.
It helps to have a hook pick (90* works well). Unlock one side's pin, then pull out on that side of the unit so the pin doesn't lock back down. Then you can unlock the other side.....
Old Dec 6, 2007 | 08:23 AM
p nut's Avatar
Yeah, must be molded on there (this deck is pretty old). So you're saying the pins come completely out? I'll go try that real quick.
EDIT: Still no go. I'm getting ready to just take a hammer to it.
Old Dec 6, 2007 | 08:33 AM
B18C_EJ8's Avatar
It's probably backstrapped then.
Remove the lower panel again and take pics of the back of the radio.
Old Dec 6, 2007 | 08:35 AM
p nut's Avatar
Default Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">It's probably backstrapped then.
Remove the lower panel again and take pics of the back of the radio. </TD></TR></TABLE>
I swear I double-checked the back, but I probably missed something. I can't take pics with my phone, but I will post some up when I get home tonight.
Thanks for your help.
Old Dec 6, 2007 | 09:30 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: (p nut)
On that model the trim is molded on I think. Its easy to get out. If you look on both sides of that radio on the inside of the trim your going to see two pins. Move both of those pins to the center and pull the radio out.
Old Dec 6, 2007 | 10:10 AM
p nut's Avatar
Default Re: (wrx-killer-Sti-eater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti-eater &raquo;</TD></TR><TR><TD CLASS="quote">On that model the trim is molded on I think. Its easy to get out. If you look on both sides of that radio on the inside of the trim your going to see two pins. Move both of those pins to the center and pull the radio out.</TD></TR></TABLE>
Yeah, there are those to pins (or levers, as I referred to them ). I tried moving to the center and pulling it out, but still stuck. Nothing should be screwed into the back, right? I saw the stock mounting points under the radio, but nothing was screwed in.
Old Dec 6, 2007 | 11:47 AM
B18C_EJ8's Avatar
Are you sure it's not backstrapped behind the radio? Piece of metal screwed to the back of the radio, then screwed to the dash somewhere?
Old Dec 6, 2007 | 12:24 PM
p nut's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure it's not backstrapped behind the radio? Piece of metal screwed to the back of the radio, then screwed to the dash somewhere?</TD></TR></TABLE>
Had some time at lunch, so I took out the bottom trim piece again and looked. This is what I found:
So, you're right. Thanks!! Just put in an order through Crutchfield.
2 - Kenwood KFC-1361S 5-1/4" 3-way Speakers 49.99
1 - Kenwood KDC-135 CD Receiver 99.99
2 - Kenwood KFC-1660S 6-1/2"/6-3/4" 2-way Speakers FREE
All of that for $149 shipped. Plus all the harnesses for free. I love Crutchfield.
Old Dec 6, 2007 | 12:30 PM
B18C_EJ8's Avatar
Default Re: (p nut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p nut &raquo;</TD></TR><TR><TD CLASS="quote">
So, you're right. Thanks!! </TD></TR></TABLE>
Imagine that.
Glad you got it out!!
Old Dec 6, 2007 | 12:33 PM
B18C_EJ8's Avatar
Default Re: (p nut)
All of that for $149 shipped. Plus all the harnesses for free. I love Crutchfield.</TD></TR></TABLE>
Actually, you could reuse your existing deck wiring harness, and sell the new one you get from Crutchfield... Prolly get ten bucks for it..
matt94z
Audio / Security / Video
Feb 15, 2009 10:58 AM
ken9
Honda Civic (2001 - 2005)
Jan 20, 2009 04:26 PM
RemoveGiantWingOnYourCar
Apr 4, 2007 05:57 AM
TMNcivic
Mar 5, 2005 02:15 PM
RTW DC2R
Dec 23, 2002 01:33 PM
