LS/V conversion
Old Dec 6, 2007 | 06:13 AM
jmoney45's Avatar
Default LS/V conversion
what do i need other than the head for the conversion and what do i need to modify???
got a 98 ls and a TYPE-R head. can i use type-r pistons and what size conversion kit should i get??
Modified by jmoney45 at 6:44 PM 12/6/2007
Old Dec 6, 2007 | 07:48 AM
CerealKiller's Avatar
Default Re: LS/V conversion (jmoney45)
all you would need is a conversion kit, Golden eagle mfg. sells their on their website. Here you go.
http://www.accountwizard.com/c...lemfg
Old Dec 6, 2007 | 10:40 AM
integrag's Avatar
Default Re: LS/V conversion (CerealKiller)
you also need much more than just the conversion kit to make a clean ls/vtec...i have on in my 94 ls and i spent less than a thousand on it(including the head), or maybe more not sure lol..so its not to expensive but i spent the money to make it run right and clean...here is a thread that helped me a lot....https://honda-tech.com/zerothread/1676914-check that thread out it will help a lot
Old Dec 6, 2007 | 10:52 AM
Davidkak's Avatar
LS Block B16 Head LSV the info that the other guys gave u should be enough...good luck on the build
Old Dec 6, 2007 | 05:45 PM
jmoney45's Avatar
tt
jmoney45
Dec 6, 2007 06:16 AM
jonnybadboi9
Jan 28, 2007 09:07 PM
DADADAAAMN
Mar 3, 2006 03:02 PM
DA6-TypeR
Feb 10, 2005 03:53 PM
