help weird cutting out when cruising
Old Dec 6, 2007 | 05:18 AM
Chris Crane's Avatar
Default help weird cutting out when cruising
help guys this is my last hope. i drive my b16 swapped crx about 170 miles a day mostly all highway and interstate driving and i have noticed in the last few weeks its cutting out (almost like it doesnt fire on a cylinder) from time to time when im cruising in 5th gear around 4500-5000 it cuts out but when i drop down to 4 grand it doesnt seem to do it as often or as bad but the problem is noticable. i have changed the spark plugs plug wire and even changed the distributor, the fuel pump was upgrade last summer and the filter was change the spring before that, this car has me and my buds stumped please help
Old Dec 6, 2007 | 05:50 AM
tecMNSTR719's Avatar
Default Re: help weird cutting out when cruising (Chris Crane)
You said that the pump is upgraded? What size?? Also, what ecu are you running??
Old Dec 6, 2007 | 05:51 AM
Default Re: help weird cutting out when cruising (tecMNSTR719)
its a 255 walbro its never gave me any trouble tho, and the ecu is a pw0
Old Dec 6, 2007 | 05:54 AM
Duane_in_Japan's Avatar
Does your engine have an EGR valve on it, if so pull the vacuum hose, plug the hose and go for your highway cruise, if the problem stops, then deal with your EGR system, FAQ's have all the info you need. If you have EGR, this is the RPM range it operates at.
Old Dec 6, 2007 | 10:13 AM
Default Re: help weird cutting out when cruising (Duane_in_Japan)
nope no egr valve, only ones i heard they came on were auto b16s mines and manual. and i couldnt locate anything in the faq.... anyone else???
Old Dec 6, 2007 | 10:52 AM
crxrocket's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris Crane &raquo;</TD></TR><TR><TD CLASS="quote">nope no egr valve, only ones i heard they came on were auto b16s mines and manual. and i couldnt locate anything in the faq.... anyone else???</TD></TR></TABLE>
maybe it is just time to put her out in the back 40 w/ the cow's bro. i hope someone can help us get it lined out
Old Dec 6, 2007 | 11:37 AM
gringo7718's Avatar
Default Re: help weird cutting out when cruising (crxrocket)
try searching the FAQ and make sure your o2 sensors are connected correctly
Modified by gringo7718 at 4:56 AM 12/7/2007
Old Dec 6, 2007 | 07:56 PM
Default Re: help weird cutting out when cruising (gringo7718)
I have been looking for a pic just like that second image for my tutorial, thanks man, I will search that site a little more for some good pics, I am building an AC tutorial, great find man, thanks.
Drostillblazin
Sep 21, 2016 03:26 PM
Rey01ITR
Honda CR-V & Element
Jun 20, 2012 11:40 AM
90dxcrx
Jan 20, 2011 06:39 PM
frog169
Apr 2, 2007 12:12 AM
Cone
May 26, 2003 07:47 PM
