Help!!!
Old Dec 5, 2007 | 07:42 PM
DreamCivic96's Avatar
Default Help!!!
I need help. Myself and a friend did a transplant for his 92 coupe to his 93 hatch. Now the engine will not idle right. Any ideas what we should look for or need to do to fix this problem??? Any help please
Nick
Old Dec 5, 2007 | 07:44 PM
SOHC_4dr's Avatar
need more info. what motor? year? what exactly happens when it tries to idle? it could be anything to make it do that. what was the last work done on the car? what work has been done on the motor?
Old Dec 6, 2007 | 04:59 AM
Default Re: (SOHC_4dr)
B16a stock into a stock 93 hatchback shell. No mods to motor or car yet. Idle bouce's back and forth between 700 and 2500. Any ideas?
Old Dec 6, 2007 | 05:03 AM
B16B_coupe's Avatar
HRD PKR
Default Re: (DreamCivic96)
iacv?
any cels?
vacum leak?
Old Dec 6, 2007 | 06:01 AM
SOHC_4dr's Avatar
what year is the motor? you sure you have the correct harness and ecu?
Old Dec 6, 2007 | 06:46 PM
Motor is a 92,shell is a 93. ecu and Harness is correct
tgkaotic
Aug 21, 2007 03:38 AM
SlowPokeEg
Mar 10, 2005 10:02 AM
Mocky57
Jun 11, 2003 06:15 PM
