q about fog lights and springs
I just installed some password jdm square fogs on my 98 and at first the switch worked fine but now all of a sudden the switch doesnt lock or something I have to hold the switch to keep them on, but it does work sometimes. if anyone knows whats wrong that would be great
also i just installed eibach prokit springs and the drop is supposed to be 1.6 in the front and 1.4 in the back but the back looks slightly lower than the front, a shop installed them so I dont know if the put em backwords or not just wondering if when the springs settle if it well look right and if I should bring it back to the shop or not
thanks
thanks
button is probably recessed too much. try popping out the switch and see if you can switch it on and off with ease while its out of the switch socket/holder.
shorter springs in the back. it might have an f or and r on the springs too.
i thought eibach is suppose you drop your car the same all around.
eibachs are known for the back being lower than the front
Modified by verycleanhatch at 10:29 PM 12/5/2007
