Any feedback on Aurora spherical rod ends as adjustable end links (teflon lined self lubricating)
Just wondering if anyone is running these rod ends as end links
I just ordered 8 (4 male & 4 female)
for under $12 each
MM-M10T (PTFE/Teflon lined)
MW-M10T (PTFE/Teflon lined)
plans are to try to run either male or female (1pc on each side) in the FRONT. and obviously 4pc in the rear... only thing is I need special collars for the front.
http://aurora.thomasnet.com/it...o=110
I think this would be a much better option than function7 or blox adj endlinks
Modified by 6SPD_EK at 9:23 PM 12/5/2007
for under $12 each MM-M10T (PTFE/Teflon lined)
If their other spherical bearings are any indication, these should be decent. We use Aurora's bearings for several spherical bearing parts with good results, although we did receive one batch that came in quite loose and some had already developed rust. I think it was an isolated incident as we haven't had problems since.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">Too bad they don't come in something like stainless steel.</TD></TR></TABLE>
the ones I listed above come with anti-corrosion coatings
[quote]Body - Carbon steel, protective coated for corrosion resistance.
Race - Carbon steel, protective coated for corrosion resistance, Ptfe Lined.
Ball - Alloy steel, heat treated, hard chrome plated. [quote]
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6SPD_EK »</TD></TR><TR><TD CLASS="quote">Just wondering if anyone is running these rod ends as end links
for under $12 each
Look like a excellent option, Did you buy them directly from the site you listed or from anothe distributor?
