CV Axle popped out??????
I have a 1993 Honda Accord with an automatic transmission. Long story short, i'm driving down the road and feels like the trans slips outta gear. I pull over and I got nothing.....no reverse or forward gears. I get towed home and pull the wheel off to find the pass side CV axle has popped out of the trans. I go ahead and replace it. But now driving I hear a noise thats similar to bearings going bad. The car had started shifting hard so I checked the fluid and topped it off now this has happened. Does it sound like I need to swap/replace trans? Thanks for any help.
are you sure the new axle is in all the way? look at the old one and see if its worn down, i believe they clip in.. so its possible the clip in the tranny is broken.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pbrskin »</TD></TR><TR><TD CLASS="quote">BTTT</TD></TR></TABLE>
uh what
uh what
thanks i know what it means.. no ones going to tell you anything different if you didn't check the clips, and two, this forum doesn't move fast enough that you'd need to bump it
hondapwr
12
Sep 28, 2005 09:17 AM
Honduh@Love
Aug 30, 2005 02:18 PM
1 speedstar
Jul 18, 2003 03:58 PM
