Full Race Stage 2 GT???
Old Dec 5, 2007 | 09:13 AM
96WhiteOnBlack's Avatar
Default Full Race Stage 2 GT???
This kit is on Turbo-Kits.com. it doesnt say if i can use this setup with stock inernals or not. What do you guys think?
http://turbo-kits.com/rsx_turbo_kits.html
Old Dec 5, 2007 | 10:17 AM
WhiteOnRice's Avatar
I say no. Full-Race is pretty hardcore.
Old Dec 5, 2007 | 10:37 AM
johnclaunch's Avatar
Default Re: Full Race Stage 2 GT??? (96WhiteOnBlack)
Output 480 HP? No way with stock internals.
Old Dec 5, 2007 | 11:21 AM
Default Re: Full Race Stage 2 GT??? (johnclaunch)
Ok, so about how much hp can I get safely with stock internals? I`d like about 300-350whp. I figure that should get me to low-mid 13`s.
Old Dec 5, 2007 | 11:36 AM
Tyte-S's Avatar
Below 300. Tranny will start to go at that time as well.
Old Dec 5, 2007 | 11:40 AM
Default Re: Full Race Stage 2 GT??? (Tyte-S)
Ok, so can I run mid-low 13`s with stock internals? If so, how? If not, what would I need to replace to safely run a 300-350whp turbo setup?
Old Dec 5, 2007 | 11:42 AM
Tyte-S's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96WhiteOnBlack &raquo;</TD></TR><TR><TD CLASS="quote"> I figure that should get me to low-mid 13`s. </TD></TR></TABLE>
Intake, Racing Header, Exhaust, KPro. You should be in or damn to close to 13's. If not, start losing weight and stiffen up the suspension, and you'll be fine.
Old Dec 5, 2007 | 11:50 AM
Oh wow! I didnt know that it reacted so well to i/h/e with a tune. So if I went bolt-on crazy and got all that plus TB, Intake Manifold, fuel rail, ect... could I go mid 13s?
Old Dec 5, 2007 | 12:13 PM
kFabb's Avatar
this is good thanks for all the info bro im looking to turbo my k20
Old Dec 5, 2007 | 12:48 PM
moores55's Avatar
Default Re: Full Race Stage 2 GT??? (kFabb)
My god man, Just end it. It's not that hard to get an rsx-s in the 13's. Do a damn search.
Modified by moores55 at 4:14 PM 12/5/2007
Old Dec 5, 2007 | 03:04 PM
02bluteg's Avatar
Yeah the k20 loves I/RH/E, add Kpro to the mix with a good tune and you'll be set.
Old Dec 5, 2007 | 03:11 PM
posHonda's Avatar
rsx-s with i/h/e/kpro from what Ive seen do high 13s. Low 13s youd probably have to get cams.
Old Dec 6, 2007 | 08:58 AM
Default Re: (posHonda)
Yeah, see thats what im tryin to stay away from. I dont wanna do any work on the internals. Well.... maybe cams.... im just scared of goin into the engine! I feel like once I do that, it wont feel the same.
I know you cant compare a 72 Mustang with a 351C to an RSX, but when I put a cam in my Mustang..... It just turned it into a loapin beast that hauled *** but didnt run great after that. That lead to head work, then I just got greedy for power. $7k later..... I didnt even wanna drive it anymore cause it was like I was drivin a racecar around.
I have read that turbo cams make a HUGE difference on turbo`d cars with stock cams but it just scares me. Should I be so leary of this or am I just being paranoid?
Old Dec 6, 2007 | 09:41 AM
blueshark123's Avatar
Default Re: (96WhiteOnBlack)
On word v-tec. And dont put cams on a turbo rsx. It isnt needed. Im making 650+whp on stock cams.
Old Dec 6, 2007 | 11:11 AM
Default Re: (blueshark123)
Damn! Ok! What all did you have to ugrade, internal wise, to support that much power?
Old Dec 6, 2007 | 11:16 AM
Wiseco 9:1 pistons, manley rods, Golden eagle sleeves, Supertech valvesprings retainers and seats, micropolished and balanced stock crank, upgraded oil pump spring, ARP headstuds. I would have just done the oil pump, spring retainers and seats if all I wanted was 460whp, maybe the ARP head studs as well.
Old Dec 7, 2007 | 05:34 AM
Ok, so how much power would I have to put to the ground to hit low 13s? And would stock internals and tranny be able to handle it?
Old Dec 7, 2007 | 06:14 AM
Some people have broke into the 12s with a greddy kit on a dc5 chassis (~300whp). Stock internals and trans should be fine. Just preload the trans and dont shift like you're in F&F and you'll be fine. Get yourself a decent suspension and Hoosiers drag radials or BFGs if you want to use them for the street and 13s should be no problem. But remember you will almost always want more power. I originally wanted only 300whp and look where Im at now....
Old Dec 7, 2007 | 12:32 PM
Lol! Yeah, im the same way! I guess if I end up wantin more power i`ll start upgrading on the turbo kit I have at the time (If thats possible) I didnt realize the GReddy kit would do that much. Is there a specific GReddy kit or is there just one? I have only found one so far.
Old Dec 7, 2007 | 02:23 PM
92gs-r's Avatar
If you want to keep your engine/trans stock I suggest a stage 1 GT kit. You can easily put 380 to the wheels and with a good K-pro tune it will last a long time.
BTW I strongly suggest an LSD.
Old Dec 9, 2007 | 05:00 AM
Aberdonos's Avatar
Hey blueshark have a question for you.. I have a 04 type s, with i/h/e I'm about to drop a stage 2 turbo in, with stock internals what is a safe range for my psi? As well i am wanting to push 350-400 Whp for the now, could stock internals handle this (safely)? and what other mods would it take to get me in this Whp range...
Old Dec 9, 2007 | 08:14 AM
Tyte-S's Avatar
Default Re: Full Race Stage 2 GT??? (92gs-r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92gs-r &raquo;</TD></TR><TR><TD CLASS="quote">If you want to keep your engine/trans stock I suggest a stage 1 GT kit. You can easily put 380 to the wheels and with a good K-pro tune it will last a long time.
</TD></TR></TABLE> Stock DC5 tranny at 380whp? Rofl Have fun with that.
Old Dec 9, 2007 | 08:07 PM
k20tuRbo's Avatar
You can make plenty of power on a stock motor, just get a good tuner. That full race kit will be fine
Old Dec 9, 2007 | 08:45 PM
JCL's Avatar
JCL
alota ppl are doing 400-500whp for dd on stock internals its just the tranny ud have to upgrade.
Old Dec 9, 2007 | 09:20 PM
Default Re: (JCL)
All I really want is 300whp. I wanna be able to safely hit low 13s on street tires. If I did end up becoming power hungry and had to upgrade my tranny, what exactally would I have to upgrade? Would I have to get a whole new tranny or just a few stronger parts? And how much would that cost me? (Say I was around 400whp)
