vtec solenoid wires?
Old Dec 5, 2007 | 08:34 AM
123Four's Avatar
Default vtec solenoid wires?
I need help I don’t know why my vtec solenoid black ground wire keep sparking when I start up the car. All I did was just put the ground wire on one of the 10mm bolt by the vtec solenoid. What cause it to spark and why is it sometime I could start up my car and sometime cant? What could the problem be and how should I ground that black wire if I was to change it location?
Old Dec 5, 2007 | 11:32 AM
ITR_Sol's Avatar
Default Re: vtec solenoid wires? (123Four)
Location is fine. your problem is deff something else in the wiring. Have you got other ground wires on your motor? just a seg.
Old Dec 5, 2007 | 04:44 PM
123Four's Avatar
Default Re: vtec solenoid wires? (ITR_Sol)
i switch all my ground wires and i also refix the vtec solenoid ground wire on the 10mm. everything seem working again let hope this is it.
thanks
Old Dec 5, 2007 | 04:48 PM
Joecivic94's Avatar
I've had the same problem on my Mini-Me, make sure the wire is only touching the place where you are grounding, if it is touching any other metal it will spark and weld itself to that metal, I did this on my car and blew my solenoid. Good Luck
CivicSiRracer69
Oct 31, 2004 11:17 AM
leprechan117
Apr 10, 2003 09:11 AM
Project92Hatch
Mar 26, 2003 01:22 PM
schwett
Jun 2, 2002 12:34 AM
