Help dash problem
When you reset the oil life and it turns to 100%, does this reset your km/miles? Because i reseted the oil life and now don't see how many miles/km i've ride till now!
What should i do for seeing the miles/ km back?
Please refer to this link for some help. I believe it should look familiar to you.
https://honda-tech.com/zerothread/2167709
Press the select/reset button to get back to the odometer.
If you accidently reset your trip meter in the process of reseting the oil life than there is no way to recover that.
Once the trip meter is reset there is no going back.
<A HREF="https://honda-tech.com/zerothread/2167709
" TARGET="_blank">https://honda-tech.com/zerothread/2167709
</A>
</A>
That code should be on a plastic buisness card somewhere with the owners manual packet.
If its not, turn the cars ignition to run, turn off the radio, press and hold the #1 and #6 preset buttons while you turn the radio on. This will give you two series of numbers. This is the serial number for the radio.
Any Honda dealership will be able to give you the code if you provide them with the serial number.
You can PM the number to me if you like and I'll give you your code. I work at Victory Honda in Monroe MI.
92hybridAccord
Aug 8, 2008 07:00 PM
