static in speakers with satellite radio
Old Dec 5, 2007 | 08:02 AM
95teg_ls's Avatar
Default static in speakers with satellite radio
alright so i recently picked up a satellite radio, and now i got it going directly into the deck through the aux port on my cd player. im getting static or a whine that matches up with my rpms, the higher the rpms the high pitched the whine. is there anything i can get to absorb or deflect the electrical interference?? i get no static with the car off and im getting power from the cigarette lighter.
Old Dec 5, 2007 | 09:28 AM
GSR-TRBO-DA's Avatar
Default Re: static in speakers with satellite radio (95teg_ls)
is it a whining noise or just static? static is bad reception most likely and if it runs off GPS then you are likely to have bad reception in parking garages, in a business district with tall buildings stuff like that. if it is a whining then check for bad ignition wires they are a good cause of this, what kind of vehicle is this?
Old Dec 5, 2007 | 10:18 AM
95teg_ls's Avatar
Default Re: static in speakers with satellite radio (GSR-TRBO-DA)
its in a dc4, only happens when i use the sat radio, but i think an fm modulator will clear it up, just want to make sure before i buy one.
Old Dec 5, 2007 | 10:30 AM
Dogginator's Avatar
Daisy... Daisy...
You most likely have a gound loop between your CD player and satellite radio receiver. Either the CD player or the satellite receiver has a poor ground.
Old Dec 5, 2007 | 10:45 AM
95teg_ls's Avatar
Default Re: static in speakers with satellite radio (Dogginator)
cd players never given me any problems before, and the radio is grounded from the cigarette lighter, i heard that since the aux port and cig lighters are so close to each other that they could be causing it, and that i should use an fm modulator.
Old Dec 7, 2007 | 07:47 AM
doesn't FM stand for frequency modulation
KILLAB17VTEC
Audio / Security / Video
Oct 13, 2009 11:13 AM
Triptweeze
17
Mar 2, 2008 04:43 PM
joeg26er
Oct 29, 2001 07:20 PM
revhrdls
Oct 13, 2001 10:20 AM
