B and D series dizzy question
so im doing a b series swap into my 99 civic and i understand that the plugs between the B and D series dizzy is different. I was wondering if i switch the plugs and if so does someone have the wiring diagram for it?'
AND
I noticed that right next to the fuel injectors is like a sensor or something and the plug that i have on my ex harness is different from that sensor what do i do?
AND
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by creepy116 »</TD></TR><TR><TD CLASS="quote">so im doing a b series swap into my 99 civic and i understand that the plugs between the B and D series dizzy is different. I was wondering if i switch the plugs and if so does someone have the wiring diagram for it?'
AND
Here you go, I was going to do this also.
https://honda-tech.com/zerothread?id=558245
AND
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by creepy116 »</TD></TR><TR><TD CLASS="quote">that didnt answer my questions. could i rewire the plugs? if so do i just match up the colors?</TD></TR></TABLE>
From what I understand, you just color match the wires, splice, etc. There is going to be a left over wire, but I forget where it goes. I'm sure someone else can chime in.
that or you can just buy a obd2b b series dizzy weather its vtec or not.. non vtec dizzy's fit ls and b20 vtec dizzy's fit b16 b18c1 and b18c5
what extra wire?
i already tried to repin obd2 clips to obd1 clips.. the pins are different.. thats why i just said to buy a obd2 dizzy
Dukie432
Apr 22, 2009 12:20 PM
slacks
Feb 22, 2008 06:30 AM
Phaze2 Mike
May 30, 2005 06:40 PM
