Issues after installing new clutch
Old Dec 4, 2007 | 08:09 PM
superchi's Avatar
Default Issues after installing new clutch
So I had my clutch installed at a friend's brother's shop about two weeks ago but I immediately noticed a few problems that weren't there before I dropped it off.
First thing is there is a leak of oil that seems pretty inconsistent. It drips a little bit after I drive. I got under the car and saw that it would land on the side of the bottom of the header and then hit the ground.
The second spot is another slow drip that is consistent after every drive. It's somewhere on the driver's side, it hits the splash guard and drips to the ground. It's hard to tell where the higher point from where its coming from is.
The third problem started happening recently, there is a big puddle of coolant underneath the car. It follows the seam where the bell housing is attached to the motor.
The car has 16x,xxx miles on it, but I've enjoyed a leak free motor up until now and am thoroughly disappointed that it is having problems. It's going back to the shop soon to track down the problems, but I was just seeing if T-I had any info they can share
jonyi27
Dec 6, 2012 12:10 AM
virtuoso
Mar 28, 2007 09:46 AM
jaycetan
Jun 11, 2005 01:17 AM
98GeeYes-Are
15
Jan 12, 2004 06:21 PM
rokestah
Jan 20, 2003 06:52 PM
