?'s about installing an itr transmission into a stock 99 si
Old Dec 4, 2007 | 08:08 PM
crxmadness's Avatar
Default ?'s about installing an itr transmission into a stock 99 si
I'm preparing to take out my stock 99 si S4C transmission & replace it with an itr transmission. I have a few questions, feel free to add anything you think I should know:
1) can i reuse my stock axles?
2) can i reuse my stock half shaft?
3) can i reuse my stock clutch or do i need to get an itr clutch
4) can i reuse my stock flywheel or do need to get an itr flywheel
5) can i reuse my stock shift linkage?
6) can i reuse my stock slave cylinder?
7) can i reuse my stock transmission mounts?
Thanks in advance for your help.
Old Dec 5, 2007 | 09:59 AM
crxmadness's Avatar
Default Re: ?'s about installing an itr transmission into a stock 99 si (crxmadness)
ttt
Old Dec 5, 2007 | 12:03 PM
okyu's Avatar
yes to all, good luck
Old Dec 5, 2007 | 12:55 PM
Andyroo's Avatar
Default Re: ?'s about installing an itr transmission into a stock 99 si (okyu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by okyu &raquo;</TD></TR><TR><TD CLASS="quote">yes to all, good luck</TD></TR></TABLE>
what he said
Old Dec 5, 2007 | 03:24 PM
crxmadness's Avatar
Default Re: ?'s about installing an itr transmission into a stock 99 si (Andyroo)
sweet, thanks for answering my questions
Old Dec 5, 2007 | 03:40 PM
ocJDM4dr's Avatar
yeap.... best of luck
Old Dec 5, 2007 | 05:29 PM
blk92_d16's Avatar
Sounds like fun! Enjoy
Old Dec 6, 2007 | 05:31 AM
newby_j's Avatar
Needs More Cowbell
Default Re: (blk92_d16)
Yes it all will fit, but i would consider putting in a new clutch while it is apart.
Old Dec 6, 2007 | 05:42 AM
posHonda's Avatar
Default Re: (newby_j)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newby_j &raquo;</TD></TR><TR><TD CLASS="quote">Yes it all will fit, but i would consider putting in a new clutch while it is apart. </TD></TR></TABLE>
I second that
Old Dec 6, 2007 | 06:04 AM
blaze the chemi's Avatar
Default Re: (posHonda)
Which ITR tranny are you putting in? USDM or JDM 98+? If you are replacing your S4C tranny with a USDM ITR tranny then you'll have the same gearing, but with a LSD I presume.
Old Mar 15, 2008 | 06:21 PM
B0R3D 4NG3L's Avatar
I'm doing the same thing, so this was helpful. the one question i have left is I assume you use the ITR speed sensor. Is that corret, and if so, does that change what my speedometer is going to say? I know that the slave cylinder and back-up sensor is the same part number.
Thanks for the help.
Old Apr 8, 2008 | 10:13 AM
another question is do you use the civic si starter, or do you have to buy an itr starter?
thanks
Old Apr 9, 2008 | 02:52 PM
BigZeke5's Avatar
Default Re: ?'s about installing an itr transmission into a stock 99 si (B0R3D 4NG3L)
same thing for the starter. your good to go. I'd definately get a clutch and flywheel while your thier. If not both then at least the clutch. Garantee you will be happy.
Old Apr 9, 2008 | 03:46 PM
Default Re: ?'s about installing an itr transmission into a stock 99 si (BigZeke5)
well, i already have a stage 2 w/ light flywheel in there. it's just that the trans is starting to go bad. after researching all of my option for the past two weeks, i decided that this was the best choice for me.
actually, one last thing that i never go answered. i have to use the itr speed sensor, right? and if so, my speedometer will still register right, correct?
i think that's the last question i have, so thanks everybody.
Old Apr 22, 2008 | 09:39 AM
BigZeke5's Avatar
speed sensor also will work with the tranny!
Old Apr 22, 2008 | 09:42 AM
BigZeke5's Avatar
Actually you can use either or. If I'm not mistake they both are the same sensor and have the same connector. Remember ITR tranny and B16 tranny are the same, only ITR has LSD. If your not planning on doing nothing with one of the sensor, I'll buy it off of you for 20 bucks. Mine does not work at all.
b20beast83
Aug 20, 2008 08:22 AM
jdmsi22
24
May 21, 2007 02:12 PM
Gaylorde
Jul 8, 2005 11:47 AM
civic596
Nov 29, 2003 04:51 AM
Audi RS4
May 31, 2002 11:01 AM
