FS: ITR cluster
i have an ITR cluster with 25,000 miles on it up for sale. it's in MINT condition. it will fit in a 96-00 civic. i will sent you all the instructions if you want to mount it in there, including the brackets i made to mount it perfectly. make me an offer on the cluster
can you elaborate on how the brackets were made, mine is just sitting in there and the bottom is fine but i don't like the gap mine has at the top, can you tell me how you got it to fit so well, also to all others, it is not hard to do at all, you just have to know how to repin the wires and you can't mess anything up cause it is all fused. Just in case you are worried bout the wiring...
mine doesn't sit perfect either, all i did was use the same plumbers tape that i used to hold the bottom in on the top. and made it as perfect as possible
This dude is very trustworthy BTW
