Help vtec!
Old Dec 4, 2007 | 05:58 PM
Jayponce's Avatar
Default Help vtec!
Vtec is suppose to pop around 6.5-7k rpms. It dose, Only every once in a while. Could a dinged up oil pan be the cause of that? Or maby its because my car is running to lean? i am Trying to save up for hondata/tune. looking at about $900 for both hondata&tune. Oh ya the car is a 1990 hatch civic si With a jdm B16aswap b16ecu b16tranny. The car is not low on oil. But its throwing the tps code and the speed cable code.
Old Dec 4, 2007 | 06:05 PM
SIred91's Avatar
Rainman
Default Re: Help vtec! (Jayponce)
Umm.....vtec doesn't "pop" or "kick" or any of that ricer bullshit. If it is working correctly, you shouldn't even be able to tell when it engages.
And unless I'm mistaken, it should engage around 5.5k if it's done correctly.
sirtef9's Avatar
fix your speedo,and TPS, Vtec should kick in around 4300 rpm to 5500 rpm depending on your ecu, is it the pr3 or pw0?
Old Dec 4, 2007 | 06:06 PM
Jayponce's Avatar
Lmfao I dont think youve driven a f*uckin vtec than Because i feel it like crazy when it dose Engage.
Old Dec 4, 2007 | 06:07 PM
Jayponce's Avatar
The ecu is also chipped so its set at 6.5.
Old Dec 4, 2007 | 06:09 PM
Jayponce's Avatar
pr3
Old Dec 4, 2007 | 06:11 PM
SIred91's Avatar
Rainman
Default Re: (Jayponce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jayponce &raquo;</TD></TR><TR><TD CLASS="quote">Lmfao I dont think youve driven a f*uckin vtec than Because i feel it like crazy when it dose Engage.</TD></TR></TABLE>
I have a CRX with a B16 you ricer. And if you have your toolbox of a car chipped for it to engage at 6.5 then no wonder you are having problems.
Holy ****.
Old Dec 4, 2007 | 06:16 PM
Jayponce's Avatar
Well instead of Posting Insults give me a legit opinion. lol "ricer" Well u kind of did. I need more details! Mr.
Old Dec 4, 2007 | 06:18 PM
sirtef9's Avatar
we did, fix your 2 codes then go from there, Clean your vtec Solenoid screan? Don't you need the speedo to be funtioning for the Vtec? I had my VSS go out in the cluster and it would cut in and out, till I changed out the cluster.
Old Dec 4, 2007 | 06:20 PM
Jayponce's Avatar
Ty ,And yes Im bad at honda talk call me a ricer for it.
Malgerus's Avatar
Default Re: (sirtef9)
Why do you want to tune it with Hondata? Isn't it basically stock? ****, don't bother paying that much for tuning.
VTEC will NOT engage with a VSS code, and probably not with a TPS code. Get your **** fixed.
Old Dec 4, 2007 | 06:27 PM
Jayponce's Avatar
Yes the motor other than the gsr cam gear its stock. What chip/ program should i go with for this stock motor ? But i plan to buy So really decent bolt ons. intake manifold, 4-1 headers, Hi performance fuel pump etc. Oh ya lol would useing a stock 90 civic fuel pump be a bad idea ? Because thats what im using atm.
Old Dec 4, 2007 | 06:31 PM
SIred91's Avatar
Rainman
The fuel pump should be fine, if its working correctly, the program in your ecu and the codes its throwing are your answers.
Get the ecu set back to stock. With no supporting mods, you are just hurting performance and mileage.
Make sure your TPS and VSS are fixed.
And yes, a dented up oil pan can affect oil pressure if it is not getting enough at the pickup. And vtec depends on oil pressure.
Take that 900 in tuning and hondata, and put it in suspension.
Old Dec 4, 2007 | 06:32 PM
Jayponce's Avatar
Can the motor become damaged if vtec isnt engaing? running front skunk2 coil overs, rear tokico blues, front after markter sway bar upper lower, rear upper lower sway bars, and skunk2 rear control arms. I looking to buy new shocks and lowering springs stiffer ride wouldn't it be?
Old Dec 4, 2007 | 06:39 PM
SIred91's Avatar
Rainman
Never cheap out on suspension. That is the MOST important thing on your car.
Get quality parts...(shocks/struts and springs)........Tokico blues are only stock repacement. Get the illuminas or Koni sport.
Vtec not engaging wont hurt anything...but you wont be getting the benefit either.
JunY
Honda S2000
18
May 17, 2005 09:37 AM
wfo
Feb 25, 2005 02:21 PM
EF4lyfe
Sep 7, 2004 04:52 PM
Gunns
13
Jun 1, 2004 11:15 PM
