Front Driver's Side Tire Rubs...
Old Jun 26, 2002 | 09:54 AM
Uncle_Ben's Avatar
Default Front Driver's Side Tire Rubs...
A couple of days ago I lowered my '98 RS on Neuspeed Sports and Tokico Blues. The drop is great, and she rides great too; however anytime i turn right, or I hit a bump my drivers side tire rubs, and only the drivers side. I am completely puzzled as to why this is... I had an alignment done hoping it would help, but the problem is still there. Any thoughts?
Old Jun 26, 2002 | 10:28 AM
badnan's Avatar
Default Re: Front Driver's Side Tire Rubs... (Uncle_Ben)
sounds like a camber problem
Old Jun 26, 2002 | 11:23 AM
cornbread's Avatar
hoe low of a drop is it?
Old Jun 26, 2002 | 04:59 PM
Uncle_Ben's Avatar
Default Re: Front Driver's Side Tire Rubs... (smokeeeLSR)
I think Neuspeed advertises a 1.75" on the front, 1.5" on the back. I took a closer inspection today of the tire/wheel well, and I think it might be that the fender liner has come loose and is coming in contact with the tire. Not 100% sure, but if that's the case it will be a lot easier (and cheaper) to fix. Just have to find a way to anchor it down close to the fender, I think the part that is supposed to hold it down to the scew has snapped or something.
Old Jun 26, 2002 | 11:20 PM
SIK IN DA HED's Avatar
New User
youre just havin normal fender rub. either roll out your fenders or take off the rubber.
Old Jun 27, 2002 | 07:51 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Front Driver's Side Tire Rubs... (dlplayboy)
fender rub is not "normal", not w/ a mild drop like that, unless he has wheels of wrong offset or too wide tires. Only doing it on one corner isn't normal, either. I'm dropped close to 2" w/ 205/50-15 tires and I have zero rubbing problems. I think you're probably onto something about the fender liner. Fix or replace it, but I wouldn't recommend removing it, it will get extremely dirty inside your fender, and on the leading edge of the door. Some gunk may even find its way into the engine bay.
Old Jun 27, 2002 | 07:53 AM
project_DC2's Avatar
Default Re: Front Driver's Side Tire Rubs... (PatrickGSR94)
wheels or tires. Check if its due to a problem.
Fender liners.......if you do take those off, then you might have to clean you engine bay every 2 to 3 days
mish__
Suspension & Brakes
Mar 3, 2013 12:08 PM
talkJDM
Suspension & Brakes
13
Jul 25, 2011 06:20 AM
oddmut
Honda Civic (2001 - 2005)
May 12, 2008 10:32 PM
zach1288
39
Aug 3, 2007 08:22 PM
GraphiteMW
Apr 17, 2007 09:19 AM
