89 Si for CHEAP! $1100 OR BEST OFFER!
My Ef is up for sale. Car has good mods and needs to be gone ASAP! buying another car, need money. If interested call me at 609-468-2381 my name is andrew.
-1989 Honda Civic Si
-d16a6 Motor, (SOHC NON-VTEC)
-Ram Air Intake (EBAY)
-Spoon Sports Header
-Custom Test Pipe
-Invidia Cat-Back Exhaust (crx version, custom to hatchback)
-Xenon Blue Headlights
-Sparco Sprint Seat on custom bracket
-Skunk2 Coilovers
-Eg Rad Gangster lean (was gonna go turbo)
-Autometer Carbon Fiber Air/Fuel Ratio Gauge
-Skunk2 Short Shifter
-Autometer 5 inch Tach with Shiftlight (make keep)
-Integra type r shift boot (real)
-KNock off civic type r shift ****
-Urethane shifter bushings
-Tow Hooks (front and back)
-NGK Plugs and Wires
-New Cap, Rotor, Distributor
-New Water Pump
-New Timing belt
-New Head Gasket
-New Valve Cover Gasket
-Custom Shaved and Painted Valve Cover
-Front and Rear Upper Strut Tower Bars
-New Clutch (oem)
-Password JDM Amber Corner Lights
-Mild Wire tuck on one side
-Sparco Steering wheel with quick release hub
-Ichibahn Pedals
-CRX SI rims with brand new tires
-75000 miles on fresh rebuild
-185000 on car, gauge cluster is not from the car.
Thats all i can remember thats on it. But i got a ton of parts ill give with the car when it is bought.
Yet again theres more but i cant remember right now.
Heres the bad:
-Smached Windshield
-Partly primered (can paint white for $500 more dollars)
-timing is off (couple degrees)
Car will run and drive. Got all fluids changed on time. Throwing a code 7 for a TPS thats it. Nothing more, nothing less.
Finally, put back together After all this time.
Asking $1100 OR BEST OFFER! that means the best offer wins!
-Custom Test Pipe
-Skunk2 Coilovers
-New Water Pump
-New Timing belt
-New Head Gasket
-New Clutch (oem)
-Ichibahn Pedals
Heres the bad:
-Smached Windshield
slammedef06
Sep 2, 2008 05:11 PM
civic89si666
Northeast (Sales)
Sep 5, 2007 09:08 PM
